Broken ball joint on A Arm please help! pics
Old April 4th, 2010, 12:27 PM   #1
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
I was turning a corner slowly the other night and i just feel something pop and my car comes to a grinding stop i take a look under the car and this is what i see.
MORE
I tried keeping the floor jack under the A arm while aligning that ball joint thinking it would maybe pop back in as i let the car back down the ground but of course im stupid and forget theres coil springs applying force downward on the A arm so it wont do sh!t.
what the ef do I do now?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old April 4th, 2010, 12:37 PM   #2
Hawaiianbro will become famous soon enough
Send a message via AIM to Hawaiianbro
hmm try and take the spring out and let it down?
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum
Old April 4th, 2010, 12:44 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
At the *very* least you need to replace that balljoint.
It may be easier to just get new LCAs, though.
O o
/¯/______________________
\_\
Old April 4th, 2010, 12:50 PM   #4
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
how do you replace that ball joint? does it have to be pressed back into the A arm??
I dont have the tools or workspace to do any new major installs so new LCA are not an option.
Would improper steering alignment cause this problem?
Old April 4th, 2010, 12:57 PM   #5
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
Balljoints are a wear item, they simply wear out over time. Judging by all that rust, it was time. The only way to fix it is to press the entire old balljoint out, and press a new one in, there's no repairing that one.
Old April 4th, 2010, 12:57 PM   #6
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
AHHHH YES, i am looking here in my Haynes manual and it is indeed the Ball Joint that is toast. and yes it says replacement: remove the lower control arm, have the old balljoint pressed out of the arm and a new balljoint pressed in by an automotive machine shop. Install the lower control arm. well shit, mines already out so i guess i just gotta have someone press a new one in! lol
Old April 4th, 2010, 01:13 PM   #7
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
you don't have to remove the a arm. if you have a shop do it they will have a tool that presses the ball joint out.
otherwise, if your gonna do it then i guess you would have to remove the a arm and have a new one pressed in
cams + 150 shot
Old April 4th, 2010, 01:34 PM   #8
2001 Bullitt
12.25@110.4
Yours isn't completely out, it's just broken, you still have to remove the housing out of the lower control arm.
Old April 4th, 2010, 01:36 PM   #9
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
yep its still gonna need to be pressed out
cams + 150 shot
Old April 4th, 2010, 03:57 PM   #10
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
To be honest installing new LCA's isn't that hard.
If you've got a floor jack 2 jack stands and a basic tool set you could do it.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old April 4th, 2010, 05:59 PM   #11
superbeef1000's Avatar
just pull off the lca`s , upgrade the bushings while you have them out and get the moog ball joints they are nice , bushings and ball joints will need to be pressed in and out
Old April 4th, 2010, 06:01 PM   #12
looks like those front end components have been sitting under water wow
Threads Similar to: Broken ball joint on A Arm please help! pics
x2 ball joint install PowerShiftz02GT 99-04 8 January 17th, 2012 12:08 AM
Ball joint? stang05 2005 - 2010 V6 4 January 25th, 2010 10:21 PM
Pics of bent push rod & broken rocker arm supermachone The Clubhouse 5 May 18th, 2008 12:02 AM
lower ball joint theodoor24 Classic Mustangs 5 April 26th, 2008 07:19 PM
Ball Joint Time.. Blown5.0 5.0 Mustangs 4 June 4th, 2007 01:37 PM
