timing chAin
Old April 4th, 2010, 01:22 PM   #1
2001 Mustang GT
realrider88 can only hope to improve
timing chAin
what is the recommendation to deal with that? what mileage on the windsor 4.6?
Old April 4th, 2010, 08:22 PM   #2
NomadGT's Avatar
NomadGT is on a distinguished road
The engine origin doesn't really apply.. Basically I would say if you have over 100k then It should be inspected and or replaced. Its a toss up, I'm the second owner of my mustang and had to replace it when I got it at 50k. The car owner loved to free rev the engine upon startup. This leads to premature failure as the chains are adjusted by oil fed adjusters. So it is really how you drive it. If you don't change oil like you should then it should be inspected, the guides tend to fail before the chains. I hope this helps you.
Old April 4th, 2010, 08:25 PM   #3
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
The timing chain replacement isn't even in our recommended maintenance guide. I probably wouldn't change mine unless there were something wrong with it.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old April 4th, 2010, 09:20 PM   #4
2001 Mustang GT
yeah i was reading the guide and didnt see anything thanks tho
Old April 4th, 2010, 10:04 PM   #5
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
i had 80K on my old 2v and when i tore it down the chains/tensioners/guides were completely fine. i wouldnt really worry about them to be honest. not unless they start getting loud or something.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old April 5th, 2010, 07:56 AM   #6
NomadGT's Avatar
I can see here that no one reads the entire post. I said it depends on use of the car. PM's is something that needs to be done, period. May be you had 80k on your odometer, but did you drive the entire 80? Did you rev the engine everytime you started it? The recommendation I gave was general. Having 15+ years wrenching on cars, you tend to see more than whats in your driveway. I have the same engine and at 50k had to replace timing chains from repeated abuse. The old if it ain't broke don't fix it program is half the reason there are plenty of grenaded engines in the yard. There's nothing wrong with being sure.
Old April 5th, 2010, 08:05 AM   #7
NomadGT's Avatar
Reading through the maintenance guide also doesn't mention the fact that you should have your brake fluid flushed either. But that is one of the causes to some brake failures.
Threads Similar to: timing chAin
Take a look at my timing chain...... ndfrspd 99-04 8 May 17th, 2009 09:55 PM
Timing Chain greengoblin 99-04 8 April 4th, 2009 04:20 PM
timing chain? ZoomZoomMFer 99-04 3 September 18th, 2008 09:19 PM
timing chain BostonPerformance V6 Mustangs 3 August 25th, 2008 05:04 PM
timing chain flattusmaximus78 5.0 Mustangs 2 August 18th, 2008 11:56 AM
