MY OTHER RIDE IS YOUR MOM
Bearing removal help
I'm in the middle of my gear swap and am trying to remove the bearings from the diff. I've tried everything I can think of except grinding down the inner race and splitting it.
I Heated them and have a 2 jaw puller but they just won't budge. I'd just leave em but the puller slipped off and fubar'd the bearing so now they have to come off now matter what. I was hoping I could do it this weekend but it looks like I might have to take it someplace with a press. Anyone got any bright ideas before I give up?
![]() “I Saw Elvis at 1000 Feet” "I was doing fine until about mid-corner when I ran out of talent." |
1997 Thunderbird
14.06 @89.53 needs tuned
Heat helps however the trick I use for the really stubborn ones is to put the puller on as tight as you can get it then smack it with a hammer. The impact will usually pop them loose enough that you can remove it.
Alan |
What are you smaking on the bearing or the puller? I tried the bearing but it didn't work.
2001 Bullitt
12.25@110.4
I used a bearing splitter/puller combo, and it came off like butter.
http://www.doityourself.com/invt/otc...4517-661725625 Last edited by Bullitt5339; April 4th, 2010 at 03:17 PM. |
#5 | |
I got the damm things off. Had to get mad and beat the sheot out of it!![]() Now I should be able to start putting it back together.
04 mustang gt
7.21 @ 98
if your replacing the race anyway (which is a good idea especially with a new bearing) then just get a punch and knock it out with a hammer from the front (driveshaft side)
just wedge it against the side of the race (punch at an angle) and go around it knocking it out in a star like pattern (back and forth) edit, read you got it out
![]() cams + 150 shot |
Threads Similar to: Bearing removal help
| spun a bearing | WNTS 2RN | 99-04 | 4 | September 8th, 2008 08:33 AM |
| Throw out bearing? | DickH | 99-04 | 3 | August 29th, 2008 11:45 PM |
| Throw Out Bearing | Lefty | 4V / SVT | 0 | June 29th, 2008 06:10 PM |
| Throwout bearing has gone out | Stagray | 96-98 | 5 | August 30th, 2007 10:13 PM |
| T/O Bearing.... | lwhitetrash88l | V6 Mustangs | 10 | August 17th, 2007 12:27 PM |
