LinkBack (1) | Thread Tools |
#1
2003 Mustang GT
11.98 @ 118.68mph
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 23 reviews
Fuel Rail Pressure Sensor help
Hey guys. So I wanted to take my car out to make sure the fuel pressure was good and everything. mell0 helped me do my dash pod and boost gauge setup (thanks andy) So I tied the boost vac line in to the fuel rail pressure sensor. I got a code saying "Fuel Rail Pressure Circuit Malfunction"
I thought maybe I pinched off a line, so I re-routed that to a differant vacuum line. Thats all set. But the on my dads scan tool, I can datalog (kind of) And my fuel pressure seem to jump around a lot. I went WOT in 2nd and hit like 65lb, then driving around it was going like 39, 38, 42, 40, 44, 39...a couple times it hit 36, and twice it hit 34...I dont know if thats too low? So is it possible that my Fuel rail pressure sensor is shitting the bed? Could I use the one off my Dad's 03 Mach 1 to see if thats what it is? Thanks for all the help guys - Shaun
![]() 2013 Mustang GT/CS 406rwhp & 397rwtq Kooks Axleback, UPR o/r X Pipe, Airaid Intake, Shaftmasters Aluminum Driveshaft. 2003 Mustang GT - Vortech 415rwhp SOLD |
Hooo Ha Ha
Well i think its going to fluctuate as you drive. Your fuel pumps have variable speeds while mine runs full power all the time
![]() 496rwhp 580rwtq @ 12psi 76mm Turbo 5.4 swap #turbo2v www.JPCracing.com 410-729-0005 |
yep, my fuel pressure gauge fluctuates as i drive around. usually between 35 and 45 like you said. and my bad with that setup for the boost gauge. a few people suggested it to me, and it's been working for me.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
#4 | |
2003 Mustang GT
11.98 @ 118.68mph
![]() But, it hit 65lb at WOT, that was odd. And you know what andy, when I was on the way back home going to my house, it started having those idle issues again too. So idk if it was because the fuel rail pressure sensor, or because I cleared the computer. But it seems to be doing okay now...every now an then its a pita.
#5 | |
2003 Mustang GT
11.98 @ 118.68mph
It might be. But, the 2 days before it was fine. Not any problems. Then stuck in traffic alittle it kind of did that. I changed the line from the Fuel rail pressure sensor, so maybe thats all it needed. It should be all set anyways, if not, Ill use my dads sensor on the Mach 1 (if itll work) and see if thats the case.
2004 mustang GT
12.5 @115
mine throws the same code. mine only does it once and awile on start up. I think mine is because I removed the check valve in the fuel tank. so when I start my car I just turn the key on wait a couple seconds and that seems to help.
Who is John Galt?
12.73@111.36
If you are data logging its supposed to read approximately 40 psi all the time. It is a computer calculated differential pressure across the injectors. An aftermarket gage is not computer corrected and will jump all over the place.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370. Mods listed in Garage. http://www.moddedmustangs.com/forums...-member-11329/ |
2003 Mustang GT
11.98 @ 118.68mph
So I think my fuel rail pressure sensor is shot. Because its hard to start sometimes, and its running like shit at idle. I can smell gas. I cant find any besides the one at Autozone its Holley and its $237. This sucks
2003 Mustang GT
11.98 @ 118.68mph
I think this is what I need to get: MOTORCRAFT 3R3Z-9F972-AA
03-04 Mustang SVT Cobra Fuel Rail Pressure Sensor MOTORCRAFT 3R3Z-9F972-AA But will it work on an 03 GT? And from what I read its cause by hitting the rev limiter. Cause it causes all the injectors to close, and the fuel spikes and breaks the sensor. Makes sence, but I havent hit the limiter in a while, so I though. Maybe I did by accident. Any help is really appriciated and reps!
2004 mustang GT
12.5 @115
Shaun have you moddified your fuel hat or lines at all? If you removed the little plastic line on the factory fuel hat try turning the key on the on position wait till the fuel pumps shut off then crank it over. this may help.
2003 Mustang GT
11.98 @ 118.68mph
Yea I usually do that before I start it. It does help sometimes. But idle is my problem. I really think its my fuel rail pressure sensor. Cause it smells rich as hell at idle, and Ive heard these are common.
#13 | |
April 2012 ROTM
but back on topic..to the OP...its normal for the pres. numbers to fluctuate like that
True blue crew founder/member #1 Newest Project: 1996 F250 XL PSD SCLB ZF5...79k stock miles Rollin' Coal Crew Founder
#14 | |
KB'd GT
Are you using a boost a pump? They can cause high pressures when they are wired post FPDM. |
2003 Mustang GT
11.98 @ 118.68mph
No boost a pump.
Can anyone get back to me on the Fuel Rail Pressure Sensor? Would this be causing rough idles, and hard starts? Because it's throwing codes for "Fuel Rail Pressure Circuit Malfunction"
KB'd GT
yes, it will. Replace it.
12.85 @ 114
how confident are you in your tune?
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cams XE270-AH + See Garage 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() PLANS ON HOLD |
KB'd GT
A "bad" tune could cause the frps to pop more often, but shouldn't cause these issues or the code.
BYAHHHH!
2001 Mustang GT
11.649 @ 119
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
yeah I have a sensor problem too.Its a code saying fuel Rail Pressure Sensor.
![]() Powered by Ford Boosted by Precision Turbo and Engine Thanks to: Wagon Wheel Performance & STL Mustangs |
2003 Mustang GT
11.98 @ 118.68mph
I wasnt at first, but now I am. I thought it was somethin totally differant. But Im ordering a Fuel Rail Pressure sensor tomorrow or Saturday
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/159853-fuel-rail-pressure-sensor-help.html
| Fuel Rail Pressure Sensor Mazda Tribute | This thread | Refback | October 17th, 2012 10:30 AM | |
Threads Similar to: Fuel Rail Pressure Sensor help
| fuel rail sensor | shawn13 | 2005 - 2010 | 0 | July 31st, 2008 07:27 PM |
| fuel rail pressure | WLJohnson05 | V6 Mustangs | 7 | June 16th, 2008 01:49 AM |
| Fuel rail pressure sensor error | yellow04GT | 99-04 | 3 | May 13th, 2008 12:12 PM |
| Fuel rail pressure? | obdnanr | V6 Mustangs | 10 | March 9th, 2008 08:12 PM |
| Some questions on DTC P0190 (Fuel rail pressure sensor) | throwedoff | 99-04 | 14 | September 6th, 2007 09:46 PM |
