2001 Mustang GT
Need suggestions. I can't get my tire off.
Well, I have a flat and cant get my rear passenger tire off. Yes i've taken all 5 lugs nuts off and the damn thing wont move. Any suggestions or tips would be greatly appreciated
Well we'll start at the beginning. With the car secure, IE on jack stands, have you put the boots to it?
well at my work we just kick the shit out of it till it comes off. or just hit the back witha rubber malet. just make sure ur car is secure
![]() Mods = stuff to make me take corner faster
You can use a sledgehammer as well. Hit the back of the tire at first, taking care not to hit the rim or backing plate... or your taint. Hit it firmly. Not with 'HOLY FUCK I'M GOING TO SMASH THIS SOCKSUCKER!!!!!" force, just firm hard blows.
Firm. Hard. Blows. And rotate the wheel as you hit it. |
semtex
www.irmfclub.com |
48.47@ 12.58
Just lower the car and let the weight of the car itself do the work. With the lug nuts off of course.
2001 Mustang GT
i have a 2x4 against the back of the rim/tire and been pounding the shit out of it but its not budging
2003 Mustang GT
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#10 | |
Note: NOT the rim.
48.47@ 12.58
You could also spray some pb blaster into the lug holes and wait about 2 minutes before you hit it.
I guarantee my size 11 3E gets it off
All I do is kick the outside bottom of the tire. Never had one that stubborn.
#14 | |
2001 Mustang GT
lol i've pounded the shit out of this thing and it's not budging. I would try but I don't trust this jack lift
48.47@ 12.58
Did you try my 2 ideas?
Do you have torches?
2001 Mustang GT
It's lowered with the lug nuts off right now. Im going to wait for tomorrow to work on it. I don't have pb blaster so im going to spray wd40 or whatever i can find.
2001 Mustang GT
Yeah i have some tiki torches
lol. yeah i have a propane torch but if you mean like cutting torches no.
No heat, fill the tire as best you can and beat the hell out of it front and back, side to side a few times. If you got a flat, you could go with plan B. Put air in the tire, spray it with soapy water and look for bubbles. Mark the spot some how, and use a tire plug kit to take of the leak with the wheel still on the car (did that a few times). If you don't trust the jack, get some blocks of wood and put them under and drop the car on to them so that the tire is still off the ground.
If you have an impact gun, put the lugs nuts back on and then take them off again. that has worked for me before. When you do get the wheel off, sand the face of the rotor where the wheel sits and use a VERY SMALL amount of brake grease to help keep it from happening again. +1 on the PB spray in the lug holes. You should also try to spray between the rotor and rim if you can.
![]() Black Stang Crew #007 Car Built By Me and CraigsList.com Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads. More to come! I hope.
48.47@ 12.58
It'll come off eventually. I would pick up the pb blaster over the wd40 honestly.
That crap works like a charm. Do you perhaps have a power washer? Odd as it sounds the water pressure could free it up. Mine just took 2 year old oil base paint off of concrete today.
Threads Similar to: Need suggestions. I can't get my tire off.
| need tire suggestions. | Ace417 | 2005 - 2010 | 36 | March 15th, 2010 09:12 AM |
| Need some tire suggestions! | LuckyFlyinRoush | 2005 - 2010 | 17 | May 9th, 2008 01:19 AM |
| Wheel and Tire Suggestions | supermachone | The Clubhouse | 12 | March 9th, 2008 10:41 PM |
| tire suggestions | mustang17 | V6 Mustangs | 5 | June 7th, 2007 03:52 AM |
| Tire suggestions | JASonic | V6 Mustangs | 2 | February 24th, 2007 08:31 PM |
