guage and temp controll lights not working
i checked the all the fuses in the car and all of them are fine..what could be my problem?
![]() Mods = stuff to make me take corner faster
anyone?
its not a fuse but a light bulbs in your instrument cluster, u have to take it apart and you will see the small light bulbs on the printed circuit board.
so one burnt bulb can cause everything to not light up?
so its the entire cluster? once you turn on your lights your dont have any instrument lights?
if that is the cause then i would check the volts coming out of your dimmer switch, that could cause the problem, if it is just a few gauges not lighting up on your dash then i would check the bulbs on your instrument panel.
the only ones that dont work are the ones that dimm.
because the theft light turn signals cheak engine lights all work.
and to cheak the dimmer switch i just put one end of the tester in the power and one to the ground?
so i just cheaked the headlight switch and the only one that doesnt work it the gray wire...which im guessing is the ground
when you turn on your headlight switch and turn the dimmer knob back and forth watch your instument cluster and your radio and a/c lights and fog lights and tac control lights, they should all dim with your instument cluster as you turn the knob, to test it you wanna use a volt meter, turn the headlight knob to the full illumination postion, measure the volts between the instrument cluster connector pin 4, wire color (LB/RD), and just use the chassis as a ground....the volts should read above 10volts. After that you wanna check the ground side of the dimmer switch. measure the resistance between the instument cluster pin 1 wire color (BK) to ground. if the resistance is less than 5 ohms then your dimmer switch is good but your instrument panel is bad......chances are is that your dimmer switch is bad, most common compared to instrument cluster going bad.
its best to check the ohms on the dimmer switch, between R1 and I1 the voltmeter will show good ohms increasing..
Threads Similar to: guage and temp controll lights not working
| coolant temp guage problems | aekrot | 2005 - 2010 | 0 | March 20th, 2010 06:33 PM |
| Water Temp Guage issue | Jeepin ina 97xj | Audio/Video | 0 | April 9th, 2009 11:26 AM |
| Intercooler water temp guage? | C MY 4D | Audio/Video | 8 | March 1st, 2009 05:13 PM |
| Water temp guage leaking | White Knight | 5.0 Mustangs | 1 | July 11th, 2008 12:55 PM |
| temp guage | sivart | 5.0 Mustangs | 10 | July 11th, 2007 06:37 PM |
