2001 mustang bullitt
how much boost????
I'm about to order the BGG 8 rib set up with the Innovators west 10% overdrive and I was just wondering how much boost you guys think I will be running.
stock diameter crank pulley is 6.5?? innovators west crank pulley with 10% overdrive is 7.25 supercharger pulley is 2.80,think that is the smallest paxton makes.
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. |
Threads Similar to: how much boost????
| Should I up the BOOST??!! | Mickey | 2005 - 2010 | 49 | October 2nd, 2009 05:50 PM |
| More boost. | jivepepper | 99-04 | 11 | July 6th, 2008 10:07 PM |
| How Much Boost? | BLOWN89 | 5.0 Mustangs | 42 | January 19th, 2008 05:12 PM |
| how much boost??? | 9stang1 | 5.0 Mustangs | 5 | December 5th, 2006 05:32 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
