410 gears what else for install
Old April 6th, 2010, 11:15 AM   #1
2004 mustang gt
40thgtvert is on a distinguished road
hey guys im a new member who just bought his very first mustang, its a 2004 40th anniversary gt vert. i have been doing alot of reading on here and even though i do do some highway driving (50mile round trip to and from work) i am gonna go with the 410s (i usually only cruise around 70mph). any way i am thinking about getting the ford racing gears from american muscle, and my main two questions are:
1. do these gears whine or make any noise
2. what else is needed for the install besides the gears (car only has 42k miles on it)
my other mods are b & m short throw and flowmaster catback (american thunder).
Old April 6th, 2010, 11:56 AM   #2
liljojo4711's Avatar
liljojo4711 will become famous soon enough
1. this is based on good installation or not mostly
2. might as well get a bearing kit, cant hurt
TOPLESS MUSTANG CLUB
Originally Posted by I8ACMRO View Post
I'll try the vaseline tonight. Thanks for the tip.
Old April 6th, 2010, 12:08 PM   #3
14.2
_Red_Rocket_ is on a distinguished road
if you're buying from AM you might as well get the optional bearing/t-loc rebuild kit.
410s will put you well above 2500+ for crusing speeds tho, probably closer to 3000 depending on what size tire you're running. just be well aware of the increase in gas milage, as well as the fact that you're crusing at 3000rpm for 50miles and have to deal with exhaust sound. I know my american thunder kit has a drone around 2k, haven't done too much crusing at 2.7-3k tho as i just got the kit.
Old April 6th, 2010, 12:44 PM   #4
3sportbob's Avatar
MY OTHER RIDE IS YOUR MOM
3sportbob will become famous soon enough
You will probably need the shims so get the full install kit. I wish I had gone that route rather than idividual parts chase(went against recomendations). I also did my wheel bearings at the same time - thanks F8L. The pass one came apart when the axle was pulled out of the way. My car only has 58k miles. Should get my shims tomorrow via fedex.
“I Saw Elvis at 1000 Feet”
"I was doing fine until about mid-corner when I ran out of talent."
Old April 6th, 2010, 04:12 PM   #5
2004 mustang gt
what about the motive bearing kit or motor instalation kit that the have as a option, wich one do i go with...??
Old April 6th, 2010, 05:43 PM   #6
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
when i put my 410s in i bought the ring and pinion install kit from randys ring and pinion, was like $65
Old April 6th, 2010, 06:15 PM   #7
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
with 410's your gas mileage will suck you broke at 50 miles per day.
I would go with the 373's, you feel it and have the response and a little less on the higher rpm. Mine runs at 2400 RPM at 70 MPH with 373's. 410's will push you to around 3000, so you'll be drinking the gas for sure.
Drive it like you stole it
Old April 6th, 2010, 07:03 PM   #8
MikeyS281's Avatar
1999 Mustang GT
14.2 no mods, bald tires
MikeyS281 is on a distinguished road
I have 4:10's in my 99 gt and the rpm's do run right at or around 2700 to 2800 at 70mph. Gas mileage did go down but notenough to bother me that much. Really the only complaint I have is that the exhaust drone is pretty loud, although I do have magnaflow magnapacks on it LOL. Anyway when I bought and installed them I replaced the rear diff gear oil and there is an additive you put in it (forgot what it is, but your local parts store should be able to tell you). That was all I did and it is still running strong, no whining or anything like that and I installed mine at around 80,000miles and now have over 130,000 on it. Drag strip, road race, highway, stop and go and still no problems!!!!
Once a Marine always a Marine!
Semper Fi Marines!
Old April 9th, 2010, 05:15 PM   #9
2004 mustang gt
Hmmm so 373s?....what is average installed cost
Old April 9th, 2010, 06:30 PM   #10
Slower than your ability to post a question that can easily be found via search
GidEup is on a distinguished road
Price varies a lot depending on where you go etc.
There's a write up here somewhere that has a pretty good list of what else you need.
Gas mileage difference is nominal...Usually when your gas mileage goes to sh!t with 410's it's because you're either getting on it all the time or you're in a lower gear than you should be thus RPM's are higher then they need to be. This topic has been beat to death; no offense.
Old April 10th, 2010, 07:56 PM   #11
2004 mustang gt
Ok I was just asking because there seems to be quite a few options on the drop down menu when ordering from American muscle. ..so should I get the rebuild kit with carbon discs and the motive bearing kit?
Threads Similar to: 410 gears what else for install
MPG 410 gears 04gtblkvert 99-04 20 December 21st, 2009 10:00 AM
410 gears whine and grind when turning GTVert00 99-04 3 August 23rd, 2009 09:44 PM
373 or 410 gears worlz08 5.0 Mustangs 23 May 26th, 2008 10:12 PM
410 install,how hard? nuffboost 99-04 14 March 7th, 2008 02:00 AM
t loc and 410 gears knightster420 V6 Mustangs 4 August 21st, 2007 08:57 PM
