buying kenne bell
Old April 6th, 2010, 11:56 AM   #1
Evil Klown is on a distinguished road
buying kenne bell
Well, i have decided to go ahead and buy the kenne bell 2.6L for my car. I have two questions, I have seen some where on the net a picture of a guys engine, he had the kenne bell supercharger with his orginal JLT CAI...Is it possible that I can keep the JLT CAI on my car with the kenne bell or go with another CAI. Also I dont wanna push the limits on the stock block past 425hp, what is the hp rating for 9 psi? I am only buying this supercharger because when i do get my new block built i dont wanna have to upgrade to another supercharger because i am running outta boost.
Old April 6th, 2010, 12:13 PM   #2
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Isn't a 2.6 a bit big for a stock 2v?
Old April 6th, 2010, 12:26 PM   #3
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
^ agreed with weems,
Sooo do you have a cowl hood or the cobra R hood cause i believe it requires one cause of its size.
im sure you read this but this is taken from kennes web site.
It has a wide boost range of 9-26 psi to cover any application or combination. It covers a power range of 500-950+HP and is recommended for any built forged piston and rod 4.6. Note: Stock 4.6 rods and pistons are rated at 450HP, so the BIG BORE 2.6L is not recommended for stock engines.
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old April 6th, 2010, 01:09 PM   #4
true, i plan on building up another block anyways, just dont see the point in buying a 6psi sc vs a 9 psi. I know about the hood clearance issues, plan on buying a cobra r hood right before i get my car painted.
Old April 6th, 2010, 01:10 PM   #5
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
If you want to be safe keep the power of a stock 2V under 400hp anythin more is questionable. The 2.6L almost certainly blow up your motor.
Old April 6th, 2010, 01:18 PM   #6
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
definitely get the 2.6l now, I wish I would have. just run the 9 psi pulley and take some timing out of it.
the inlet location is different with the 2.6 so I don't think your jlt will work, you could get it to work with the 2.1 since it's location is in a more stock location
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old April 6th, 2010, 01:23 PM   #7
yeah i think the pic i saw was on the 2.1 with the JLT CAI
Old April 6th, 2010, 01:25 PM   #8
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
I'd just get the 2.6L and *when* (not if) your motor blows. go big!! haha , you'll already have a great blower all you would need is the supporting mods to make a monster!
MM + Cleavage member #22
Old April 6th, 2010, 01:28 PM   #9
true, i am ordering a short block and building it from there. right now im just beefing up my rear end and suspension, in the process of gutting out my interior.
Old April 6th, 2010, 01:58 PM   #10
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
I would build the block and then get the 2.6. If you are planning on doing both in near future, don't jump the gun. Start with the block. Then add power.
And the kb is an excellent choice
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 6th, 2010, 02:59 PM   #11
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I agree with this 100% The only way I'd go boost before shortblock was if it was going to be a loooong time before you could do both. Sounds like you can do both in a timely manner, so why not just build your shortblock with the blower on that, and then drop the whole assembly into your car instead of having to install the blower twice?
Do the Right Thing, Cook. ~Zip.
Old April 6th, 2010, 03:04 PM   #12
Big Rob's Avatar
02 Mustang GT
Big Rob is on a distinguished road
+1^
Or install it run around like a maniac, blow ur engine and get ur moneys worth. Then play it safe on the other engine. I however agree with Ryan & Cook.
Old April 6th, 2010, 05:19 PM   #13
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
your really gonna like the KB...by all means get the 2.6 and just pulley it down for 9psi!! as for the JLT on a 1.7/2.1 it is very do-able...to my knowledge only moosenuk and myself have a jlt on a KB 1.7/2.1...limited has a demolet intake I think...but for sure get the 2.6!
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old April 6th, 2010, 09:42 PM   #14
kodiak is on a distinguished road
I went with the kenne bell big tube kit with 90mm maf and switch chip. If you run stock maf it will be pegged anyway so get the big tube. Also with that setup and a 10 lb pulley which I run on 2.1. I build 11.5 psi of boost. You will also need a 75mm tb.
Old April 6th, 2010, 09:52 PM   #15
April 2012 ROTM
I used everything from the big tube kit minus the big tube lol 90mm maf+75mm accufab+JLT fenderwell= straight sex imo
Old April 6th, 2010, 10:01 PM   #16
01GTstang11's Avatar
2001 Mustang GT
01GTstang11 can only hope to improve
not trying to steal your thread or anything lol but I was also wanting to get the 2.6L kenne bell and was wanting to know all the mods I need to do before I put the beast on. Check out my garage for all my mods so far
Old April 6th, 2010, 10:08 PM   #17
Were you able to fit 90mm maf to your jlt. I hate the tube from kenne bell. Ive been wanting to replace the tube itself. Can you tell me exactly your setup. maybe was even thinking about jlt ram air kit just dont know what will fit and dont want to waste money. thanx
Old April 6th, 2010, 10:33 PM   #18
Granny Shifter
NO_PI_NO_POWER's Avatar
1997 Mustang GT
12.297@113.47
NO_PI_NO_POWER will become famous soon enough
Send a message via AIM to NO_PI_NO_POWER Send a message via Yahoo to NO_PI_NO_POWER Send a message via Skype™ to NO_PI_NO_POWER
03 Cobra JLT goes right in.
1997 GT 2.6L Kenne Bell Build Thread
1989 LX
Old April 6th, 2010, 11:10 PM   #19
April 2012 ROTM
Yes sir the KB big tube kit has nice hardware (maf & TB) but the tune itself is cheap as hell IMO. The only think i had to do to get the 90mm MAF to fit in was take a razor blade to the inside edge of the 90 degree coupler that goes into the fender and bevel it a little...that and the slightest amount of grease and just worked it in. also for a 1.7/2.1 your gonna have to take about 3 inches out of the centersection so that the tube isnt kinked
thats a thing of beauty
Old April 7th, 2010, 10:05 PM   #20
Whats your guys opinion on running the jlt ram air kit. Kenne bell says never run an under hood cai but it seems like a nice kit also
Threads Similar to: buying kenne bell
Kenne Bell 2.1 huggy bear 99-04 27 November 4th, 2009 01:51 PM
kenne bell 1.7 mystang0673 99-04 9 June 4th, 2009 01:14 PM
kenne bell justin025 96-98 11 February 12th, 2009 07:12 PM
kenne bell punkafi888 General Tech 43 April 4th, 2007 03:52 PM
