Help
Hi,
Can I put 2003-2004 cobra Eaton Supercharger directly on 2001 Ford Mustang GT? if yes does the engine need modification? The Eaton Supercharger which I have includes everything Lower intake manifold, fuel rail, injectors, EGR valve, bypass valve,plenum and throttle body,TPS sensor, IAC valve everything do you I need to put all these sensors instead of the stock of the Mustang GT? Thanks ----------------------------------- |
As far as I know you need an adapter that torqtech makes. I'm not sure If I spelled that right but because our heads are different we require an adapter. Thats all the info I can give you.
TorkTech
Thats who makes it, yes it will work. You'll need a 90MM Maf, 42# injectors, SVT Focus fuel pump, and the rest of the kit.
Camber Bolts $20 ship OBO! 2011 5.0, 2nd MT82, 3.73's, Amsoil SS 10w-30 & MTG, GT500 A/B, Barton Bracket, BBR Billet LCAs, JLT Separator, FRPP Strut Tower Brace, BMR Springs/Adj Panhard Rod/LCA relos, Koni Sport Shocks/Struts, GT500 USM's |
!FACEPLATED!
^as they said. plus search and you will find all the answers u need
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
IMO not worth the trouble
