Re installing lash adjusters.
Old April 6th, 2010, 05:42 PM   #1
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
Question
Ok so I've bleed these things with a vice but still cant get the followers (rockerarms) on with the cams in. If I rotate the cams to get them in the chain jumps the teeth on the crank sprocket throwing my timing back off. What am I doing wrong?
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx 92gt short block w/gt40p, explorer intake, 65mm tb, 373 gears, 76mm C&L maf, tubular K-member 14.15 @ 94 (5000' above sea lvl)
Old April 6th, 2010, 05:55 PM   #2
yellow04GT's Avatar
2004 mustang GT
12.5 @115
yellow04GT is on a distinguished road
why is your chain jumping teeth? are you turning the engine over or just rotateing the cam?
Old April 6th, 2010, 06:02 PM   #3
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
Im not real up on my cam stuff..yet ...but why do you have it timed before you have the rockers in it?
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old April 6th, 2010, 06:03 PM   #4
ajm
google Otc-7928 --- problem solved
As to the post above. You time it then install the rockers/followers/whatever prefer to call them. That way youre not fighting the force of the springs trying to rotate the cam as well as not shoving valves into pistons.
The chains shouldnt be jumping either when you rotate them. Are the tensioners installed and then the tensioner guide pressed towards the chain some to where theyll apply tension? Or are you trying to rotate just the cam(s)? rather than rotating the crank which would then rotate the cam(s)
Old April 6th, 2010, 06:05 PM   #5
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
I'm rotating the cam but my tensioners have no oil pressure since i pulled the engine apart to swap blocks. So the chain has some slack in it. LOL Otc-7928 I was hoping it wouldnt come to that.
Old April 6th, 2010, 06:07 PM   #6
ajm
Press on the tensioner guide by hand and youll hear a slight click or 2 and then let off. That will cause the tensioner to pop out some, then the catch will hold the piston in place/itll apply pressure on the chain(s).
Old April 6th, 2010, 06:16 PM   #7
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Thanks Ajm i'll try that tonight. Is this the safe mode i read about online?
Old April 6th, 2010, 06:32 PM   #8
yellow04GT's Avatar
2004 mustang GT
12.5 @115
if you dont have the lash adjusters and followers installed you valves do not move. they would be closed.
Old April 6th, 2010, 07:03 PM   #9
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
I'm rotating the cams. Should I be rotating the crank instead?
Old April 6th, 2010, 07:11 PM   #10
ajm
yea
Old April 6th, 2010, 11:27 PM   #11
01MGGT has a spectacular aura about01MGGT has a spectacular aura about
I just rotated the crank to get each one in. Get in as many as possible per rotation. I seem to remember using flat tip screw driver, maybe?
375hp 380tq
Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper
vids
http://www.youtube.com/user/01mggt
Mineral Grey Club member #14
Military Crew E-4
Predator Crew Chief Holloman
Old April 7th, 2010, 12:27 AM   #12
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
I have one for sale......
They are a pain in the ass, thats for sure
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old April 7th, 2010, 09:26 AM   #13
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Ok...I think I'll get it done tonight. Thanks again guys. Update tomorrow on progress.
Old April 7th, 2010, 06:14 PM   #14
ajm
No problem. Best of luck to you.
Old April 8th, 2010, 09:25 AM   #15
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
Well it only took me about 45 min to get them in. just buttoning everything else up now.
Threads Similar to: Re installing lash adjusters.
how to remove the lash adjusters B0B 99-04 4 July 12th, 2009 01:57 AM
Lifters/lash adjusters texas96gt 99-04 4 December 12th, 2008 10:13 PM
Valve lash Adjusters interfac9 99-04 31 September 18th, 2008 05:59 PM
Solid lash adjusters zerofx150 99-04 8 March 16th, 2008 09:59 PM
