2001 mustang gt & 86 gt
9.84(86stang)
something broke
hey guys i got an 01 mustang gt 5 speed and when i go in reverse it feel like my back end shifts also if im on a sharper turn and give it some gas it feels like the back end is shifting out of place a makes a noise. i know im not sliding out or anything so can anyone tell me what this could be. thanks. also when im driving it drives just fine only in reverse and if im not giving it enough gas, if i give it a lil bit more gas than normal it does nothing.
White Mustang Crew Member #8 2001 white mustang gt- exhaust, intake, 96k 1986 mustang-shootin for 9.8 this year, will have vids soon
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Sounds like a muffler bearing...
Jack the thing up and take a look. It could be numerous things. Were not going to be able to pin point exactly what it is. |
!FACEPLATED!
could be control arm bushings or even a torque box came loose on you
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
i literally loled at a muffler bearing.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
those muffler bearings do tend to throw the back around and cause problems with reverse! Low blinker fluid could also be the culprit!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
13.82@100.26
Nah.. its definitely a bad transmission belt tensioner. You're going to need to get a new one.
Boost gets you laid
your upper torque box probably broke.. pretty bad deal if thats the case, but it happened to me.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
9.84(86stang)
thanks guys, also its when i shift it kinda struggles to go into gear. its not grinding or anything just gotta put a lil bit more strength into it. think it could be low on fluid?
could be low in fluid, or actually it could be too full. a fluid change wouldn't be a bad idea though.
!FACEPLATED!
How many miles on the car? unless you have a leak, it shouldnt be low on fluid. Chances are your clutch needs to be adjusted
9.84(86stang)
ok thanks
9.84(86stang)
its got 97k on it right now. i was thinking the same thing also cause thats what we did on the other stang. but it just started doing it so didnt know if it was something diff. thanks
Bringing Yellow Back
my buddy had the same problem with his fox, kinda sucked to fix but we got it done
9.84(86stang)
yeah, i hope its nothing to big. lol.
Threads Similar to: something broke
| new best and something broke | SWEET2KSTANG | 99-04 | 36 | October 27th, 2008 08:48 AM |
| GF Broke up with me. | 99mustanggtman | The Clubhouse | 69 | September 10th, 2008 11:47 AM |
| So Im now broke.... | zinc02GT | The Clubhouse | 30 | July 17th, 2008 03:14 PM |
| When i say im broke, I MEAN IT!! | TurboLX | The Clubhouse | 18 | July 8th, 2008 11:42 PM |
| Broke again..... | C MY 4D | 5.0 Mustangs | 20 | July 28th, 2007 06:21 AM |
