So I've assembled my parts list...
Old April 6th, 2010, 08:25 PM   #1
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
OK here goes.
I bought this 2000 GT with 80K miles on it a while ago for $1920. I will be pulling the engine and trans to rebuild if I have enough money before November. The engine will be getting all new gaskets, seals, rings, bearings, timing chain, tensioners and valve springs. The trans will get new bearings and blocking rings/syncros.
It needed some minor repairs but nothing I couldn't handle.
As of now I've completed a list of all the parts, performance and appearance for what I want. The car will be a street strip car but not my DD, since I have my 6er as well. I'm going to lay out the list with links to what I've found to be the lowest prices on those parts. If you happen to know where I could get a better deal on the said parts please let me know. I'm trying to save as much money as possible on the parts. I'm not looking for low quality parts since I want it to be a reliable car but I don't want to pay more than I have to. Also any suggestions are greatly appreciated as well as feedback on any parts that you've used/tested/own.
My goal for the car is to see around 400 RWHP and 430 RWTQ.
NOTE: Any Ford parts I can get at invoice pricing since I work in a dealer. I'll price them out next time I get chance but if you know of a low price please let me know. Sometimes it ends up being the same or cheaper.
Anything with a * next to it I already own.
Performance:
KB 2.1L 9 PSI intercooled kit - $5000
Includes
Billet BIG BORE Twin Screw 2.1L Supercharger
Hi-Flo Inlet Manifolds
Billet Bypass Valve Assembly
Bar and Plate Intercooler ("Intercooled" kit only)
HD Heat Exchanger ("Intercooled" kit only)
Intercooler Pump ("Intercooled" kit only)
Water Fill Reservoir ("Intercooled" kit only)
Re-calibrated Mono Chip
36lb Injectors
BOOST-A-PUMP™
Fuel Rails ('96-'00)
160° Calibrated Thermostat)
Ford GT Supercar pump -$159.79 Rock Auto, $138.78 Dealer
Ford Racing 31 spline T-lok w/ carbon discs - $239.99 LMR
Moser 31 spine hardened axles (2) - $269.90 Summit
Ford Racing Alum DS - $255.95 Summit
*Ford Racing 3.73's - $20
Bearings/Fluid - Dealer?
Steeda Tri-AX Shifter t-45 - $179.95 AM
Shifter gasket - $10.95 AM, Dealer?
Spec Stage 2+ Clutch kit 10 Spline - $359.99 AM
Spec Alum Flywheel 8 bolt - $334.99 AM
*BBK H pipe
*Flowmaster 40 Cat back
Engine rebuild - Ford?
Trans rebuild - $150 Ford
POSSIBLE SHORTBLOCK:
MMR 4.6 Street Mod 600 (up to 600 RWHP) $2499
Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
New Ford Racing Cast Iron Crankshaft rated up to 600HP (8 bolt or 6 bolt)
New 4340 5.933 MMR (Modular Mustang Racing) I-beam Rods, these rods are
shotpeened, magnafluxed and weight matched w/ ARP Hardware
New Forged Manley lightweight pistons
Speed Pro file fit rings (precision file fit to your application,
nitrous, blower, turbo or N/A)
Tri-metal Rod and Main bearings
Complete Pro Assembly and Balancing for the smoothest, highest revving
shortblock available, Pre-Lubricated with Royal Purple Assembly Lube and spin tested. Lastly 3 technicians sign off on your new engine prior to packaging and crating.
Options:
Upgrade to MMR block side bolts (recommended for 500+ HP) +$44.99
MMR Street/Racing Oil Pump (highly recommended) + $159.99
MMR/Felpro Extreme Duty Headgaskets + $169.99
ARP Headstuds +$269.99
7 quart oil pan +$299.99
Suspension:
MM FLSFC's - $119.00 MM
j&M CC plates - $164.99 AM
H&R Race Springs - $249.99 AM
Tokico HP rear shocks (2) Factory shocks are leaking. -$119.98 AM
UPR Pro Series Chrome Moly Adj LCA's with double spherical bushings - $169.99 UPR
Tires/Wheels
Black Chrome Saleen Rims
18x10 rear (2) - 389.98 AM
18X9 front (2) - 349.98 AM
275/35/18 Sumitomo HTR z II (2) - $244.00 TireRack
285/35/18 Nitto 555R (2) - $556.00
Styling:
Mach 1 Grill -$54.95 Dealer, 69.99 AM
Mach 1 Chin Spoiler - $96.48 Dealer, $99.99 AM
15% Tint - $125
Smoked fog lights - $89.99 AM
Dark Smoked head lights - $199.99 AM
Smoked Tail lights - $12 VHT
Fresh Paint Job - $2000-$3000
ESTIMATED TOTAL: $12,500 + $3370 If I do an MMR shortblock.
Obviously this is going to take some time to complete and of course performance will be done first.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old April 6th, 2010, 08:28 PM   #2
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
man it sounds like you got your build on lock! good luck with it man and keep us posted on how it goes...cant wait to see the progress come together!
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
Old April 6th, 2010, 08:42 PM   #3
mell0's Avatar
2002 Procharged GT, STR
12.503 @ 113.08
mell0 is just really nicemell0 is just really nicemell0 is just really nicemell0 is just really nice
Send a message via AIM to mell0
you could actually go with the SVT focus pump instead of the GT pump, especially considering the kenne bell kit comes with a BAP. the SVT focus pump install is a breeze, and it coupled with the BAP will be more than enough for 400rwhp.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Old April 6th, 2010, 08:54 PM   #4
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
+1 looks like a good start.. its gonna be a lot of work and money but it will be a nice car when its done. add a couple k to that and you'll have a more realistic price.. theres small shit that will nickel and dime you into the thousands.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old April 6th, 2010, 09:30 PM   #5
GTermi's Avatar
GTermi will become famous soon enough
i agree, use the boost a pump with this. or get a cobra tank! awesome design
My Car- 2004 Mustang GT
Her Car- 2011 V6 Auto Premium
Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide!
Old April 6th, 2010, 09:43 PM   #6
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
get your GT pump at Lethelperformance.
Get a Grill Delete and mach1 splitter at AM.com
if your goin into the engine get some pistons and rods man you wont regret the extra confort! But nice list man!
Old April 7th, 2010, 12:30 AM   #7
2004 V6 & 2000 GT
Thanks. I'll be sure to keep updates going as I get them. It's a long term build considering that I'm working part time while I'm in college.
Thanks for the input, I'll look into that. What is different between the two installs? Does the housing for the pump have to be modded in any way more so than the other?
Yeah but that's why I'm hoping my dealer connections will get me a price break. Also since I'm doing all the work myself I think the only real expense that I cant do myself is tuning it.
Is the Cobra tank better because it's sumped? How would that help in the long run?
I was thinking about it but I won't be able to afford it before November. I was thinking about seeing how long this one would last before I go forged. I know I'll probably want over 500 after I get 400 and over 600 after I get 500. That's just the way it goes.
I'm thinking about keeping it at 400 for a while enjoying it and saving up for a stronger full forged bottom end.
Thanks for the input guys. I appreciate it.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 7th, 2010, 12:56 AM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Why not throw in a built shortblock while your at it?
With a built MMR block you could go way past 400rwhp with that setup. Skip the paint job and you wont even go up in price
410rwhp 520rwtq @ 12.9 psi
Old April 7th, 2010, 01:09 AM   #9
2004 V6 & 2000 GT
The paint job was a last step finishing touch. I could put it off even longer. It's not like I really care about what it looks like so much. Hell it kinda adds to the, god that car looks awful, it must be slow thing.
I might do that. The problem is going to be getting a place to keep the short block since I live in an apt complex... Maybe I'll just order it all at once and save my self the time and hassle of it. That's like a years pay with no fun for me though. Lol.
Although I don't need any of the other stuff to get the performance I want... I'd just need it so that I could get traction.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 7th, 2010, 08:12 AM   #10
stangpride04's Avatar
04 GT
stangpride04 is on a distinguished road
if you order little by little you'd probably get frustrated and more than likely sell it all and the car half way through. i know that's what i'd do. better to enjoy what you have save big and buy big and do it all at once so you're not skipping or skimping on anything and you'll have yourself a sweet ride you're off to a good start though! 3.73s with a kb will be perfect.
If the Westboro Baptist Church is allowed to protest at funerals of slain soldiers than I think I will just have to back the @$$ end of my stang right up to their doors early on a Sunday morning and dump the freakin clutch...
Old April 7th, 2010, 09:55 AM   #11
mell0's Avatar
12.503 @ 113.08
the SVT focus pump is literally a drop in replacement. same size as the stock fuel pump. the GT pump requires a bit of modification to the pump itself and the fuel basket. there are a bunch of threads regarding the GT pump installation that you can check out.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Old April 7th, 2010, 10:08 AM   #12
2004 V6 & 2000 GT
If I decide to up it to 500+ RWHP and a built bottom end would the SVT Focus pump be able to keep up?
I looked at some of the threads about the Focus/GT pumps. Some people say that the Focus pump can't handle more than 400 RWHP with the BP, because it will max out the duty cycle.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 7th, 2010, 10:47 AM   #13
cedsks's Avatar
cedsks will become famous soon enoughcedsks will become famous soon enough
svt focus pump should have no problem, if you find that the pressure is not to par, install an inline pump to increase pressure and flow rate. just make sure that you have a reduction method ready like a vavle or orafice plate.
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft.
Old April 7th, 2010, 10:51 AM   #14
2004 V6 & 2000 GT
I'm not so much worried about pressure as I am delivery. If the pump can't flow enough fuel because the duty cycle is maxed it's no good to me.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 7th, 2010, 12:25 PM   #15
mell0's Avatar
12.503 @ 113.08
well kenne bell designs the kit so that the BAP works with the stock pump. the guy i bought my BAP from is running just an SVT focus pump with his kenne bell setup, and he is making just over 430rwhp, so i would bet the SVT pump and BAP could get you close to, if not over 500rwhp.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Old April 7th, 2010, 01:46 PM   #16
2004 V6 & 2000 GT
Ok cool. I think I'll do that.
I'm going to go ahead and get the KB first and the supporting mods I'll need too. I might hold off on the alum fly wheel and ds for now as well. But I think that I need 3.55s at least to run the blower. So I might still have to build the rear before I do anything.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 7th, 2010, 02:00 PM   #17
mell0's Avatar
12.503 @ 113.08
well if you're going to do the clutch, you might as well just do the flywheel too. get it done while you're in there.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Old April 7th, 2010, 03:39 PM   #18
BYAHHHH!
2001 Mustang GT
13.874
i dont see a focus pump with BAP gettin you over 500...honestly I say your lucky at 460 if that...IMHO.
If your dropping the tank why not get a GT and not worry about it? Yes little mods but hell I am 19 and with some friends help did it....I am you can as well!
Old April 7th, 2010, 05:15 PM   #19
Granny Shifter
NO_PI_NO_POWER's Avatar
1997 Mustang GT
12.297@113.47
NO_PI_NO_POWER will become famous soon enough
Send a message via AIM to NO_PI_NO_POWER Send a message via Yahoo to NO_PI_NO_POWER Send a message via Skype™ to NO_PI_NO_POWER
With full boost available at 2,000rpm, I'm sure you could use 2.73's if you wanted. I like the 3.73's in mine, but 3.55's are nice too. If you're putting a forged shortblock in, don't mind adding a hood, and you have someone to tune it, remember the 2.6 is an option
1997 GT 2.6L Kenne Bell Build Thread
1989 LX
Old April 7th, 2010, 05:23 PM   #20
2004 V6 & 2000 GT
If I run the GT pump won't I also need an upgraded FPDM?
I think I'm just dreaming when I talk about the short block. I didn't want to spend over 10,000 for everything. I'll probably ditch the paint and call it a day with everything else and just run 400 RWHP. I'd probably be more than happy with it that way.
Although if the engine ever does go, then I'll get a short block.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Threads Similar to: So I've assembled my parts list...
Gt Parts List HRV6STANG The Clubhouse 26 March 31st, 2010 10:42 PM
stroker, buy a shortblock, or buy parts and have it assembled? 94pacecarSVT 99-04 23 March 3rd, 2010 10:44 PM
parts list... LXpat93 5.0 Mustangs 4 June 27th, 2009 02:20 AM
Parts List jblood37 99-04 8 April 14th, 2007 05:53 PM
SVO Parts List quikstang2 SVO 8 January 25th, 2007 09:15 AM
