Power window
Old April 7th, 2010, 12:33 AM   #1
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
Power window
So I'm driving home, and my stupid passenger window does not go down with the driver window switch, but it does go down with the passenger side switch, I cheked the driver switch, and it is fine. I can't seem to fiqure out why it won't go down or up with the driver side switch
Thanks in advance
Black Stang Member #13
315's Crew Founder
My Track Videos
Old April 7th, 2010, 12:49 PM   #2
2001 Mustang GT
anyone
315's Crew Founder
My Track Videos
Old April 7th, 2010, 12:55 PM   #3
3sportbob's Avatar
MY OTHER RIDE IS YOUR MOM
3sportbob will become famous soon enough
sounds like a bad switch or disconnected.
will it go up with the drivers switch?
“I Saw Elvis at 1000 Feet”
"I was doing fine until about mid-corner when I ran out of talent."
Old April 7th, 2010, 12:57 PM   #4
2001 Mustang GT
It does nothing with the drivers side switch, but works fine with the passenger side switch.
315's Crew Founder
My Track Videos
Old April 7th, 2010, 01:25 PM   #5
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
Sound like a loose electrical connection or fuse bro. Our switches are pretty tough but sometimes the electrical terminals come loose.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old April 7th, 2010, 01:28 PM   #6
2001 Mustang GT
i checked all fuses, and looked at all terminals on switches, i even took apart the actuall switch, i was thinking if i can swap your switch into mine just to see if it is actually the switch or something else
thanks bro
315's Crew Founder
My Track Videos
Old April 7th, 2010, 01:29 PM   #7
Too Soon, Junior!
03 GT Vert
Sure thing, I'll be taking the entire thing apart anyways when I repaint the interior.
Old April 7th, 2010, 01:35 PM   #8
2001 Mustang GT
oh cool, let me know when you'll be taking it apart
315's Crew Founder
My Track Videos
Old April 7th, 2010, 01:37 PM   #9
Too Soon, Junior!
03 GT Vert
How about this weekend? I just need to run out and get the correct sandpaper and some masking tape.
Old April 7th, 2010, 01:39 PM   #10
2001 Mustang GT
Thumbs down
yea sure give me a call, i get out work at 3:30p sat and sun
315's Crew Founder
My Track Videos
Old April 7th, 2010, 01:45 PM   #11
Too Soon, Junior!
03 GT Vert
um... yea... I'll probably be getting up at 3:30 sat and sunday lol
Old April 7th, 2010, 01:46 PM   #12
2001 Mustang GT
cool beans!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
315's Crew Founder
My Track Videos
Old April 7th, 2010, 01:48 PM   #13
ZenMGT's Avatar
'02 GT 5spd
ZenMGT will become famous soon enough
I vote for a bad mechanical switch. It's usually the pieces we physically touch/move that fail.
When you took apart the switch,,exactly what did you do?
Best thing would be to take a multimeter and set it 'ring' to test for a short. Then touch the two connectors for the switch,,,make sure it makes NO sound,,then physically push the button to make the window go down, and you should hear it beep/whine/make noise. Then you would know for a fact the switch is good.
Then you're chasing a wire problem. If that's the case, then you need to isolate the two wires that provide your pass. side window fuction. One should be 'hot' with 12V, simply short them with a piece of wire/paperclip - you should activate the window.
Obviously you'd have taken the whole switch mechanism out of the door to do these tests.....
...if you make it up to Boca this week I'd be happy to test it for you.
boringly stock........but running well
Old April 7th, 2010, 01:49 PM   #14
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
If it turns out to be a switch I have one for sale.
An easy check would be to run a test light on it. Check to see if power comes to the switch at all. If not then your problem is before the switch. Check to see if power comes out of the switch when it's engaged, if not then it's the switch. If power comes to the switch and out from the switch when it's engaged then you have a problem after the switch where it runs over to the passenger side. At least that would narrow down where you had to look for a problem
Do the Right Thing, Cook. ~Zip.
Old April 7th, 2010, 01:50 PM   #15
Too Soon, Junior!
03 GT Vert
I think it's funny that when a button or switch doesn't work, our first instinct is to hit the button harder. Especially on remotes with dead batteries.
Old April 7th, 2010, 01:51 PM   #16
2001 Mustang GT
lol
315's Crew Founder
My Track Videos
Old April 7th, 2010, 05:00 PM   #17
iTrader: 7 reviews
When you smash da buttons the remote werks gooder
Old April 7th, 2010, 05:12 PM   #18
ZenMGT's Avatar
'02 GT 5spd
you know,,,,,in a way,,,on certain devices this holds true. As you're actually smashing the contact pads down on each other harder,,,,,providing more surface area for contact,,thus better electron flow.
....certain devices,,certain situations...
Threads Similar to: Power window
Power window help Itkix 96-98 4 February 3rd, 2009 07:58 PM
power window issues. ColdSteel 96-98 5 November 26th, 2008 09:02 AM
Power window problem lottathought Audio/Video 1 April 11th, 2008 07:03 PM
Power window! Serefire V6 Mustangs 29 April 10th, 2008 09:06 PM
power window problem supercharged04 99-04 5 March 30th, 2008 06:26 AM
