Bringing Yellow Back
v6 springs in a gt?
i was wondering if i could put v6 springs in my 02 vert? also if that would lower my car, i work at a salvage yard so i can get my hands on some pretty easily. or should i get a set of gt springs and just cut them? just want some advice on this topic, thanks
2001 Mustang GT
12.70@ 113.50
![]() ![]() ![]() iTrader: 3 reviews
just get gt springs.
![]() 403rwhp/403rwtq. M.A.D. #11 |
how much should i cut out of the gt springs then?
From what I've heard you don't want to cut your GT springs because their not linear, they're progressive. There's a few "dead coils" you might be able to get away with cutting off but thats only gunna give you like a 1/4 inch drop. You're better off to just spring for a pair of lowering springs. If you maybe spend a couple hundred bucks you will have a much better ride quality. A lot of the guys on here have them. They can give you some idea of which ones to get.
Ok Thanks
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
If you can get some GT springs for cheap, get them and cut like 1/2 coil out of each and put them in. Drive it for a week. If you want it lower, pull them out and cut a little more out. Keep cutting until it sits where you want it.
If you ever get tired of the ride quality or have any problems with the cut springs, just throw your stock springs back in or buy some actual lowering springs.
Do the Right Thing, Cook. ~Zip. |
!FACEPLATED!
. There are a lot of guys here running cut springs with no issues. Hell I think even shapeshifter has been running cut springs for a few years. I to am also running cut springs. 1/2 coil cut 4cyl springs in the front and 1/2 coil cut stock springs in the rear
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
Thanks A Ton Guys, Ill Probly Cut Them This Weekend Seeing That I Have A Hoist I Can Use, Ill Keep You Poseted And Get Some New Pics On Here
!FACEPLATED!
Where is Edgerotn WI?
2001,Ford,Bullitt Mustang
u can cut them as much as u want but its not goin to ride very good at all
just south of madison, bout hour from IL
Priest of the Car Gods
o rly? u don think springs kin be cut rite?
idc im cutting them, if i dont like them then ill put stock ones back in
Just make sure to make the cut surface match how the uncut surface was, i.e. if the top of the spring is flat, after you cut the spring, pound the top of it flat again. It's the failure to match the old setup that causes cut springs to have such a bad rap when it comes to ride quality.
yea ill grind them so there is a flat surface to on
Baker Jr.
Mine are cut, love em,
best way to get the stance you want, they are proggressive so you CAN cut them, guy above in the first few posts was backwards
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Thanks Bandity
#18 | ||||
LOLZ
Nope, the other guy had it right. It's better to cut linear springs because you don't really change the spring rates. Cutting a progressive spring changes the rate, that's why everyone has a cow about it.
Well Thats What Il Going To Do That Then, And It Is A Two Post Lift,
Also The Reason All The First Letters Are Caps Is The Way The Forum Does It, I Alwas Leave My Caps On Here At Work So It Easier For People To Read Work Orders, When I Post Some Thing It Puts All The First Letters Caps And The Others Small |
MM's Official Lucifer
Makes my eyes hurt. LoL. IF you are going to cut your springs, I'd follow the suggestion of picking up a junker set to do it on, that way you can swap back your stockers if need be. I've always been one to say no to cutting, but its because of what has been pointed out here, most times it isn't done properly and thus leads to poor results. As shown by the others members who successfully run cut springs it can be done if done right.
And it is progressive rate springs that you DON'T want to cut, aka, Stang springs, because you will most likely change the rate by removing coils. This is why I'm normally against it, because people just chop off whatever without thinking of what they're doing to the rate, and don't know to match it as close as possible to the stock springs contact surfaces and coil position.
Threads Similar to: v6 springs in a gt?
| Drag springs or lowering springs??? | AggieStang | General Tech | 10 | February 18th, 2012 12:45 PM |
| steeda sport springs or steeda comp springs | mustang2517 | 99-04 | 3 | April 3rd, 2008 07:27 PM |
| Are v8 front springs noticeably different vs. 4 cyl. springs | 90hatch | 5.0 Mustangs | 3 | August 8th, 2006 06:23 PM |
