Stripped my thread
Old April 7th, 2010, 12:12 PM   #1
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
Stripped my thread
Last week my spark plug had backed out on me and i was lucky that there was no damage. I was able to put the plug back down. Than again yesterday it happened same plug. I pulled the plug and it was bad the little prong was pressed all the down and the rubber boot had split open. The threads on the plug looked good. I get one new spark plug and a new boot. I have done this job a hand full of times. Every oil change i pull the plugs and run them down. Well i was pissed about this happening, i put lock tight all over the new plug dropped it in into the head and started to tighten it up.
Im pretty sure i cross threaded it. It tighten up really quick didnt feel right. But i was an idoit and just kept going really slow and than it just broke free. I know i striped the treads in the head. It is the plug on the passenger side right by the throttle body. It looks stripped the plug threads still look ok.
How can i fix this. Can a thread chaser work or do i need to helicoil it?
Fire it up, burn it down.
Old April 7th, 2010, 12:18 PM   #2
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Helicoil coil can work but a triton time sert it the best but the kit is expensive.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old April 7th, 2010, 12:36 PM   #3
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
The car is in a parking lot and im getting frustrated with all of this. I called a good Mustang shop here and its 250+tow. I just might get the car to my house and park it for awhile. This was just at the worst time possible.
That kit looks good but ya little expensive. I bet that is what the shop uses that i called.
Old April 7th, 2010, 12:44 PM   #4
jivepepper's Avatar
It's what I have works great.
Old April 7th, 2010, 01:15 PM   #5
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
I had one blow out and took al the threads with it. went to autozone here and got a kit from Helicoil called Save a thread. worked great for me. IT comes with a special tap that cuts out the threads for the helicoil insert with out you having to drill anything. I did it witht he head still on and no issues. just used a lot of grease on the taps flutes, cut half a turn, backed out cleaned tap, re-greased... repeat untill done. then used a shopvac with a few feet of fuel lie taped into the hose to get into the cylinder just incase anything had fallen in (just a few smallish chips, but I didnt want to fubar anything) put some permatex on the insert and screwed it in. there is a second tool that you use as a punch to flare the top edge of the insert out so It graps the walls. 2 years later it is still runing great. Kit cost 25 bucks if I remember.
granted, the timesert is better, but hey, we cant all have a ton of money for that. now If I ever get different heads then I would look into that.
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
Old April 7th, 2010, 01:24 PM   #6
jivepepper's Avatar
Plus with the timesert there's a lot more steps. I packed it with grease and would only clean the fluts when they were full.
Old April 7th, 2010, 06:04 PM   #7
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
i also used the save a thread, and it has worked for 2 weeks. pretty easy to do. like said, just use tons of grease and a vacuum.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old April 7th, 2010, 06:46 PM   #8
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Originally Posted by AndrewA. View Post
Stripped my thread
I'll strip your thread
Seriously though, jive is right. Time sert is a better kit. I have the kit in my garage. Paid like 400 bucks for using it once. If you lived closer you could some use it for some beer.
You'll need a vacuum with some straws or something taped to the end of it, and just be careful!
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Threads Similar to: Stripped my thread
stripped bolt Monster90 99-04 18 January 18th, 2009 07:05 PM
Well I stripped a stud! MustangMatt96GT 96-98 21 September 20th, 2007 07:29 PM
Stripped Screw Ticket-Me-Yellow V6 Mustangs 1 May 9th, 2007 10:18 AM
Stripped Out Interior? luke 200 5.0 Mustangs 15 November 19th, 2006 11:55 AM
Stripped Interior turp Pictures 15 September 25th, 2006 04:28 PM
