Need DD help asap!!!!
Old April 7th, 2010, 01:05 PM   #1
2003 Mustang GT
zak2006 is on a distinguished road
Talking
Last night installed new mishimoto radiator after install went to start car and all I got was clicks. I disconnected the battery and hooked back up, car fired right up. Went to start this am nothing but clicks( thank god it's nice and I have 2 wheels ). Just tried to start during my break, more clicks. Unplugged the battery and plugged back in started right up. Shut up and tried to start clicks. Didn't do this before rad swap last night. And there is nothing electrical about the rad swap except for unplugging fan, a/c plug, and a plug on fan shroud. It's supposed to rain friday so I need the problem solved, any ideas???? Thanks guys!
Old April 7th, 2010, 01:13 PM   #2
Smartoss's Avatar
1999
Smartoss is on a distinguished road
I've seen this happen when the battery terminals are loose or corroded, try cleaning them and tighting down the cables.
1999 Black GT 5 speed
SLP Longtubes, O/R X-Pipe, LM1 catback, MM Full length SFC's, H&R super sports with MM camber plates
Old April 7th, 2010, 01:15 PM   #3
TheUNZippee!'s Avatar
If that doesn't work, try tapping the case of the stutter with a hammer while someone turns the key. Try to avoid getting your penis caught in the fan belt.
If that works, the starter is fucked.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old April 7th, 2010, 01:19 PM   #4
2003 Mustang GT
Terminals are clean, look almost brand new, and I have them very tight. Car runs great when it's running: smooth and quiet. I saw an old thread about a ground wire down low on the driver side near the battery but not much was mentioned about it.?.?.
Old April 7th, 2010, 01:21 PM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Starter relay, possibly.
O o
/¯/______________________
\_\
Old April 7th, 2010, 01:22 PM   #6
Old April 7th, 2010, 01:23 PM   #7
2003 Mustang GT
I will try the starter after class. But why would it start after I diconnect and reconnect the terminals? Is that a common problem when starters go bad? The clicks are loud and sound strong.
Old April 7th, 2010, 01:25 PM   #8
2003 Mustang GT
Any way of testing the relay? Don't know anyone with a stang to swap it out real quick, unfortuantley all my friends like 4cyls
Old April 7th, 2010, 01:33 PM   #9
That would be assuming the connections are dirty and/or corroded, and upon removing and cleaning them, there will be sufficient connection for the electricity to travel from post to clamp and thus into your starter thus turning the flywheel and enabling you to hit up the Sonic drive thru
mmmm Sonic
Old April 7th, 2010, 01:59 PM   #10
2003 Mustang GT
Clean terminals didn't get me to school let alone sonic
Old April 7th, 2010, 02:56 PM   #11
Fuck!!!
Old April 7th, 2010, 03:14 PM   #12
1992 Lx
11.39@119.24
lol at fan belt
Old April 7th, 2010, 03:29 PM   #13
My gut says starter.
If not, musta somehow pulled on a ground wire or something while doing the job...
Old April 7th, 2010, 09:02 PM   #14
2003 Mustang GT
well i just went out and removed the battery terminals from the cables. i blended the wires neater than they were with the multiple ground coming in and put the terminals back on and wala car starts right up. going to buy some new terminals tomorrow and going to do an even better job with the wires. thanks for all the input guys!!!
Old April 7th, 2010, 09:19 PM   #15
Glad it's nothing too bad then man
Threads Similar to: Need DD help asap!!!!
need help...ASAP! VSR13 V6 Mustangs 8 February 5th, 2009 05:35 PM
Need to know ASAP, please help darkhorse50 5.0 Mustangs 6 January 21st, 2009 08:06 PM
help asap silver_96 96-98 33 March 4th, 2008 11:58 PM
NEED HELP ASAP!! 92stang0802 2.3 Mustangs 5 October 30th, 2007 10:04 PM
NEED HELP ASAP!!! Basics V6 Mustangs 19 October 18th, 2007 10:33 PM
