wheel spacers - Page 3
Old April 8th, 2010, 10:01 AM   #41
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Originally Posted by mrsinister2424 View Post
1" spacer "adapters"(those which bolt on to your hub, then the wheel bolts onto the adapter), will not fit stock wheels. WILL NOT FIT STOCK WHEELS.
What happens is the bolts from the hub will run into the wheel before you can bolt it down all the way to the adapter. To try and paint a picture in your mind, look at your 5x4.5 pattern.
It kinda looks like this:
Imagine your studs in the middle of each round end, now take and put the spacer over the hub, and you'll have the spacer studs sticking out in the middle of each rounded end. And the hub studs will be protruding since they are longer than 1" thus running into the wheel.
Jazzer man, I think I've got you on this one
EDIT: Sorry if this doesn't make any sense, I've had a buncha beer this afternoon. But the info is right
Most people just cut off the chunk of the wheel stud that sticks out past the spacer
Do the Right Thing, Cook. ~Zip.
Old April 8th, 2010, 10:02 AM   #42
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Originally Posted by Jazzer The Cat View Post
^ That is a LOT of spacer for a set of 10"s. You'd better be VERY careful to inspect clearance of fender so you don't chop your tires all up.
Jazzer
Originally Posted by Pittbull View Post
That's wat I'm worried about...^^^
You'll have to have that car sit a little higher in the rear. If its dropped on say... H&R SS it'll rub without fenders rolled, and might even rub with!
My car sits on H&R SS with 10.5's and a 1/4" spacer in the rear, and when the car is on a slanted hill and the body is rolled, I can't even fit a finger between the fender and tire.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old April 8th, 2010, 10:27 AM   #43
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
See "I ain't no vegetarian... I want FAT MEATS!" section of Choosing a new tire thread for a way to confirm clearance when wanting to run different off-sets, wider wheels or larger diameter tires on your ride.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old April 8th, 2010, 10:30 AM   #44
Abyssinian of AX
'02 Saleen
19.34@42.259
Oh, sinister... here's a finger for ya
Jazzer = Success
Old April 8th, 2010, 10:42 AM   #45
Pittbull's Avatar
2001 Mustang GT
If you're not first you're last
Pittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to behold
iTrader: 6 reviews
Send a message via AIM to Pittbull
Oh damn... Well for now I have the stock 4x4 ride height but I do plan on lowering it at some point. I'll check out tha thread jazz, thanks.
I guess when I get em on I'll take a look and c wat I'm dealing with. If worse comes to worse I'll just take the spacers off and replace my studs
Stock Rear Springs FOR SALE! PM Me
Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me
Old April 8th, 2010, 10:50 AM   #46
Abyssinian of AX
'02 Saleen
19.34@42.259
Replacing studs is a PITA!!!!!
I have done it to run my 1/2" spacers and REALLY should have taken the axles out to do so, so see ***THIS*** thread for more info.
Jazzer
Old April 8th, 2010, 11:07 AM   #47
Pittbull's Avatar
2001 Mustang GT
iTrader: 6 reviews
Well fuck... Hopefully they won't rub :-/
Old April 8th, 2010, 12:14 PM   #48
99' Mustang GT
3214@OVER 9000!!!
Jazzer = Success
Here's what I think of your "meats"
Check garage.
Old April 8th, 2010, 01:11 PM   #49
Abyssinian of AX
'02 Saleen
19.34@42.259
Threads Similar to: wheel spacers
Wheel Spacers?? topless281 99-04 10 March 14th, 2010 05:35 PM
Wheel spacers boblongtv V6 Mustangs 7 November 4th, 2009 12:29 PM
Wheel Spacers Black Betty 99-04 4 December 9th, 2007 11:43 PM
wheel spacers MisterFast3 V6 Mustangs 1 October 28th, 2007 01:15 PM
