wheel spacers
will wheel spacers fit stock wheels on a 2000 gt
LED third brake light to replace old sun damaged one, shorty antenna, new PI Intake Manifold with aluminum crossover (my original was all plastic). Bosch Platinum 4 Spark plugs (awesome set)
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
oh yeah. they will work. i have a set of spacers I'm going to use with my set of Stock '99 Cobra wheels. it will look MUCH better with spacers out back on stock wheels
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
well i ask because on AM on my stock GT's (the 5 spoke design) they say for use with aftermarket wheels only or something like that
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
As long as you get wheel spacers to fit the stock wheels, the wheel spacers will fit the stock wheels. LOL
I'm confused by your question. As long as you get spacers that are 5x4.5" (114.3mm) they'll fit your hub. Just dont' get too wide or your tire will rub the outer wheel well
Do the Right Thing, Cook. ~Zip. |
They probably say that because they don't want you to push a stock wheel out too far, so they tell you to use them with aftermarket wheels that have different offsets. They'll work fine with a stocker unless you go with some stupid big size
Well this is a copy and paste from AM
Design: Hub centric Center Bore: 70.5mm Bolt Pattern: 5x4.5" (5x114.3mm) to 5x4.5" (5x114.3mm) Spacer width: 25mm (0.99") Note: These Wheel Spacers are specifically made for aftermarket wheels and will NOT fit stock factory wheels. this is just the 1 incher
Abyssinian of AX
'02 Saleen
19.34@42.259
That is a 1" spacer and will work with an OEM wheel on your car
![]() I am not a fan of such spacers and think you would be better served by getting wider wheels to get the look you like. More expensive, but fat meats is where it's at ![]() Jazzer
lol hehe. In his rear end?
Abyssinian of AX
'02 Saleen
19.34@42.259
The Jazzer =
lol that symbol is a really weird symbol for gay haha
#12 | |||
What happens is the bolts from the hub will run into the wheel before you can bolt it down all the way to the adapter. To try and paint a picture in your mind, look at your 5x4.5 pattern. It kinda looks like this: ![]() Imagine your studs in the middle of each round end, now take and put the spacer over the hub, and you'll have the spacer studs sticking out in the middle of each rounded end. And the hub studs will be protruding since they are longer than 1" thus running into the wheel. Jazzer man, I think I've got you on this one ![]() EDIT: Sorry if this doesn't make any sense, I've had a buncha beer this afternoon. But the info is right
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
13.82@100.26
lol... what would a wheel spacer behind an 8in wheel look like anyways? I've been wanting some for my 9in's but i'm just going to go get a 10.5in wheel... and i'm pretty sure you can't space that anymore. Sinister you rolled your fenders to make that work didnt you?
#14 | |
It looks
![]() Maybe I'll go dig up some oldddd sinister's ride pics. Shits fer fags though. Hold on.
#16 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
*DOH*I forgot about that part of it and just figured that AM didn't want pepes to install them and want to return them due to rubbing of tires. They will work, if one cuts the ends of the OEM bolts so that they don't protrude past the spacer itself. Either way, I am still a fan of a wider wheel (The Jazzer says, more MEAT!) or replacement longer/stronger lug-bolts such as the way I have installed my own 1/2" spacers. Jazzer ![]() EDIT: some wheels have a recessed area that will allow these studs, so even though OEM wheels may not work, some others will |
so what kind of wheels do i have to get for wheel spacers to work
#18 | |
![]() Its alright Jaz. But you are correct, some wheels have recessed spots behind the wheels. You CAN chop some off the studs, but I don't think its much worth it considering spacers on stock wheels is kinda ghetto anyways. Judging by his sig pic though, hes got stock lil 16" wheels, and +1 to the meat!
#19 | |
![]() ![]() Much betta: ![]() Uhm.... aftermarket wheels?
Abyssinian of AX
'02 Saleen
19.34@42.259
Betta still
![]() Jazzer =
Threads Similar to: wheel spacers
| Wheel Spacers?? | topless281 | 99-04 | 10 | March 14th, 2010 05:35 PM |
| Wheel spacers | boblongtv | V6 Mustangs | 7 | November 4th, 2009 12:29 PM |
| Wheel Spacers | Black Betty | 99-04 | 4 | December 9th, 2007 11:43 PM |
| wheel spacers | MisterFast3 | V6 Mustangs | 1 | October 28th, 2007 01:15 PM |
