Mach 1 Heads on a SOHC block
Old April 8th, 2010, 07:40 AM   #1
1999 Mustang GT;1991 lx
RoushRacing99 is on a distinguished road
what other mods will have to be done to put mach 1 heads on a sohc block?
Old April 8th, 2010, 09:20 AM   #2
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
Search man. It has been covered countless times.
2V to 4V Swap Article
2v to 4v swap
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old April 8th, 2010, 10:07 AM   #3
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
mach 1 heads are the same as like 99/01 cobra heads I'm pretty sure. Basically you have to get the whole top end from a mach/cobra for it to work
Do the Right Thing, Cook. ~Zip.
Old April 8th, 2010, 10:22 AM   #4
SS Ball3r will become famous soon enough
i am going to assume that it i cheaper in the end to buy a completed motor out of a wrecked car?
Old April 8th, 2010, 10:43 AM   #5
iTrader: 7 reviews
Not necessarily. If you can source out a bunch of used stuff for a decent price then it's cheaper to piece something together. But you have to know your stuff and know EVERYTHING that you need. Plus it takes more time.
Old April 8th, 2010, 10:55 AM   #6
I guess you could piece one together over time and not be out of pocket any LARGE expense at one time. In that regard it might be better.
Old April 8th, 2010, 05:25 PM   #7
The deal is I got a shortblock out of a 2002 Crown Vic for $75.
I am going to build it into a decent engine for my 99 GT over the course of a year or so on an engine stand. I'd like it to still be streetable, stay n/a, but still make in the 300-350ish amount in hp.
One day, I may go crazy with the engine (maybe pull my current 4.6 and have some real fun with another Mustang) but my 99 has 130,000 miles on it and the car has a lot of importance to me and I'd like to keep this car.
I want to build a good, reliable, strong engine that if it had to be a daily driver it could be (I don't plan on it though) but it will still get people's attention.
I was offered a set of Mach 1 heads. I've been looking at Trickflow but they sort of defeat my purpose. I guess what I'm asking is would the Mach 1's be my best bet or is there another alternative?
Old April 8th, 2010, 05:37 PM   #8
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
You can definitely make that much power with the TFS heads N/A with a decent set of cams, but it will cost a pretty penny. It would be worlds easier than embarking on piecing together a 4v swap......
Why do the TFS heads defeat your purposes?
Old April 9th, 2010, 10:30 AM   #9
iTrader: 7 reviews
Mach heads are going to be better than TFS heads. 4v>2v sorry guys
Old April 9th, 2010, 11:07 PM   #10
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
agreed, and if I had the opportunity to go 4v I definitely would. It's just a much more involved swap.
Old April 10th, 2010, 12:50 AM   #11
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
99/01 heads are not the same as the 03/04 but they are very close. With all bolt-ons minus LTs I made 300rwhp. If you swap the 03/04 intake cams out with 96-01 4V intake cams with LTs you'll be in the 320-335rwhp range. Or you could redo the whole valvetrain with an aftermarket set of cams and be in the 370rwhp range depending on what cams you choose.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old April 10th, 2010, 12:59 AM   #12
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
you need everything... just go buy a 4v motor.
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Old April 10th, 2010, 01:24 PM   #13
I've already got the 2v block with no heads. I'm building this block from scratch and dropping it into my 1999 GT
Old April 10th, 2010, 01:34 PM   #14
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
If you're gonna do 4v heads, why would you saddle them with a crank that can't handle the rpm that makes 4v heads awesome? You're also going to create the heaviest possible iteration of an N/A 4.6L. It's not gonna be that much more expensive to find an aluminum Cobra block, which will net you a forged crank, making up for the extra weight of the heads.
Unless you can get the 4v heads for REALLY cheap, you'll be better off with the trick flows.
O o
/¯/______________________
\_\
Old April 10th, 2010, 07:53 PM   #15
point well taken
Threads Similar to: Mach 1 Heads on a SOHC block
stock mach 1 block Saleenwolf720 99-04 68 September 2nd, 2007 03:32 PM
GT block vs Mach 1 block 02MiNeRaLgRaYGT 99-04 3 August 3rd, 2007 04:17 PM
2v sohc heads (removal) Invictus 99-04 3 June 13th, 2007 07:11 AM
1996 4.6L SOHC Block vs. 1996 DOHC Block mustangman36578 96-98 3 March 27th, 2007 03:36 AM
