It never ends, diagnostic help...
Old April 8th, 2010, 08:06 PM   #1
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
P1127 - h02's downstream sensors not tested
my car has no balls, it eats shit when i floor it, hooked it up to a scanner, doesnt misfire, fuel pressure is good even when driving it...this is the code that came up but before i had a code that said h02's swapped so i switched the wires and it went to the current P1127 code, i havent done any work to make this occur it just sort of happened one day, like i said it runs like a bag of ass i can feel it breaking up and it has no power... like i said again there was no misfire when running a diagnostic test...any ideas??
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old April 8th, 2010, 08:40 PM   #2
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
There was a time where one of my COPs wasn't even working, and no CEL lights came up. No codes, no nothing.
I'm thinkin its a misfire, or if the code that's given is right something wrong with the o2s
http://home.comcast.net/~miracerros/...wertrain_2.htm
EDIT: I'm not sure, it says exhaust isn't hot enough, but o2s have heaters, and shouldn't throw a code while the car is cold. Maybe its just as simple as an o2 replacement. Does it sound like its running on less than 8 cylinders? Popping in exhaust at idle?
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old April 8th, 2010, 08:58 PM   #3
02 Mustang GT
wouldnt i get a code on the scanner for a misfire though? and sorry if this is a dumb question but what are COP's? Also, it does pop at idle and doesnt feel like the power is there but not sure why.
02 Mustang GT
Old April 8th, 2010, 09:43 PM   #4
99' Mustang GT
3214@OVER 9000!!!
Coil on plug. And when 2 of my COPs were out I didn't get a code, didn't say anything was wrong, even though it felt like molasses when driving. almost felt like something was holding it back, and it would buck really badly when in the throttle, exhaust sounded all weird too.
Check garage.
Old April 8th, 2010, 11:19 PM   #5
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
If you have recently disconnected your battery or reset your KAM (Keep Alive Memory) your car has to relearn what normal is and won't set a code for a misfire until it does.
This can take several days of normal driving before it completes it's "Drive Cycle."
If you haven't recently reset KAM or disconnected the battery and have made a repair or alteration to the vehicle, try letting it reset and then drive it. That way it will relearn how to operate normally.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old April 9th, 2010, 12:00 AM   #6
02 Mustang GT
i have had my battery on and off for a while now, and also i pulled a wire off the plug and it looked like it wasnt even touching the top of the plug... im not sure i will try to do some work to it tomorrow or this weekend and see whats up
02 Mustang GT
Old April 9th, 2010, 12:02 AM   #7
2004 V6 & 2000 GT
You have wires on your 99+ Mustang? Do you mean that it looks like the Coils weren't touching the plugs?
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 9th, 2010, 12:04 AM   #8
02 Mustang GT
oh and also i have a p0602 code which is a CTRL Module Programming code which is from when i swapped my motor, but after the swap i never had any problems until now, the motor i got was out of an 01 and my car is an 02 but i dont think this has anything to do with that.
02 Mustang GT
Old April 9th, 2010, 12:17 AM   #9
2004 V6 & 2000 GT
I looked up that DTC on the Ford dealer only website for you. Here's what Ford says.
P0602 - Control Module Programming Error This Diagnostic Trouble Code (DTC) indicates programming error within Vehicle ID block (VID). VID data corrupted by the scan tool during VID reprogramming
Using the scan tool, reprogram the VID block.
If PCM does not allow reprogramming of the VID block, reflashing PCM will be required.
Looks like you need to take it in and get your PCM reflashed.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old April 9th, 2010, 12:19 AM   #10
02 Mustang GT
yeah thats what the scan tool told me, and also not really wires but the spring running from the coil to the plug
02 Mustang GT
Old April 9th, 2010, 12:23 AM   #11
2004 V6 & 2000 GT
I'd start with the reflash before replacing any coils if I were you.
There may be some small differences in the way the engines run. Make sure that when you go in you tell them that you put a different engine in it.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Threads Similar to: It never ends, diagnostic help...
Need help diagnostic problems jtmccalmant 5.0 Mustangs 11 July 11th, 2009 04:03 PM
I need some diagnostic help. 03_StangGuy 99-04 2 October 25th, 2008 04:28 PM
Diagnostic HELP!!! ThreeHonks302 The Clubhouse 8 June 1st, 2008 09:49 PM
Free Diagnostic? Stang6899 V6 Mustangs 7 December 12th, 2007 01:49 PM
got an engine diagnostic BlackIce V6 Mustangs 12 February 12th, 2007 01:27 PM
