Car shut off and locked up while driving+rep
LinkBack (1) Thread Tools
Old April 9th, 2010, 01:50 PM   1 links from elsewhere to this Post. Click to view. #1
spike spiegel's Avatar
spike spiegel is on a distinguished road
this mourning my car's fuel light was on .I went to the gas station and got 8 bucks worth off gas,I got back in my car my gas light was still on .I drove up the block and my car shut off while drivng ,I was going about 50mph,I had to use alot of arm power to turn the wheel and pull over,then I waited a sec,Turned the car back on,The gas light went off And I had a quarter of a tank ,The car drove great all the way to work
Any one no what could have caused this thanks
[2000 blue mustang gt vert 5spd,stalker bodykit,18'' cobra rims,lowered 2'',light bar,k&N cai,roush side exhaust,x pipe,pp 75mm tb & plenum Pro5.0 3:90 gears,Custom 91 octane SCT tune 2000 red VW jetta,auto stock
Topless Mustang Club Member
Old April 9th, 2010, 01:54 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
weird
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old April 9th, 2010, 01:55 PM   #3
dansgt's Avatar
03 gt, 95 740i, 96 disco
dansgt has a spectacular aura aboutdansgt has a spectacular aura about
how old's your fuel filter? may have just got plugged up, when you run real low on fuel it'll suck up any crap from the bottom of the tank and that may have restricted flow enough to stall the engine.
Old April 9th, 2010, 02:12 PM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Fuel pressure sensor or I'm sure there's a sensor or two in the tank for the level. Maybe one of them is acting up.
Old April 9th, 2010, 02:13 PM   #5
goren813's Avatar
'00 3.8L & '05 4.6L
^Or filter. Just weird that it ran fine after all this, clogged filter normally won't unclog on its own if its bad enough to stall the car.
Old April 9th, 2010, 02:29 PM   #6
dansgt's Avatar
normally no, but its entirely possible it picked up something big enough to block the flow and as soon as he turned it off it stopped pumping and whatever could have fallen free.
Old April 9th, 2010, 02:46 PM   #7
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
did you leave the car running when you got gas. I know if i fill mine up with the car running the guage will stay on E but SLOWLY rise. So i just turn it off and back on and it resets the sending unit. That may be your "still showed E with gas light" ordeal.
As far as the car dieing.... 8 bucks is not much. did you possibly turn sharp at a higher speed causing the gas to slosh away? Hell, who knows as far as it dieing.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old April 9th, 2010, 03:12 PM   #8
the car wasnt running when I put the gas in.I was acclerating to pass a car though when my car locked up
Old April 9th, 2010, 03:22 PM   #9
goren813's Avatar
'00 3.8L & '05 4.6L
True. If its running fine now I'd ignore it ... obviously the car didn't have enough fuel for a split second but obviously its cleared up now.
Old April 9th, 2010, 03:29 PM   #10
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
I had this happen ONCE when I was going WOT on the onramp. It died, and I just dumped the clutch in 4th going like 50 to start it back up. I pulled over and checked to see if anything was wrong, and couldn't find anything. I'd imagine it COULD be some air or fuel problem.
I've not had the problem since, it might just be a fluke man
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old April 9th, 2010, 05:05 PM   #11
Just went on my lunch and its running great...weird I just dont want my GF driving it and it locks up on her
Old April 9th, 2010, 07:42 PM   #12
dansgt's Avatar
ya i've had it happen a couple times, when i first got it and like a year or so ago, i think its just something weird with the fuel system glitching. now wheres the reps promised lol
Old April 9th, 2010, 07:48 PM   #13
trent2590's Avatar
trent2590 is on a distinguished road
yea i want reps too
LED third brake light to replace old sun damaged one, shorty antenna, new PI Intake Manifold with aluminum crossover (my original was all plastic). Bosch Platinum 4 Spark plugs (awesome set)
Old April 9th, 2010, 09:53 PM   #14
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
its prolly your cars way of saying "you cheap ass give me more gas" lmfao im jp man.
Thats def weird!?
MM + Cleavage member #22
Old April 9th, 2010, 10:33 PM   #15
yellow04GT's Avatar
2004 mustang GT
12.5 @115
yellow04GT is on a distinguished road
I wonder if you were just about out of fuel when you filled up. Then accelerated and drew alittle air. But $8.00 should give you 3 galons, so Idk only guessing. But strange for sure.Like I tell my wife it cost the same to keep it full.These things have low fuel lights.(never seen mine)
Old April 13th, 2010, 01:26 PM   #16
rep was givin to all
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/160562-car-shut-off-locked-up-while-driving-rep.html
Car shut off and locked up while driving+rep This thread Refback May 6th, 2011 12:06 AM
Threads Similar to: Car shut off and locked up while driving+rep
Engine Shut off while driving, Now wont start. Please help.. koessl 96-98 21 March 11th, 2010 10:35 PM
Engine Shut off while driving 91 gt 5.0 5.0 Mustangs 9 July 12th, 2009 12:17 PM
stupid car locked up bobnasty 99-04 18 June 11th, 2009 03:21 PM
keys locked in car 4.6gtmarine 99-04 26 June 11th, 2009 02:55 PM
locked my carkey in car can some one plz help 95 mustangmiz V6 Mustangs 64 March 27th, 2007 02:43 PM
