Fixing Up My Fuel and Ignition System
Old April 9th, 2010, 04:29 PM   #1
jake1191's Avatar
jake1191 is on a distinguished road
Send a message via AIM to jake1191 Send a message via Yahoo to jake1191
I would like to know what is a good fuel rail setup and if it is worth going with 42# injectors on a cams/heads full bolt on GT motor.
Right now it has longtubes, off road x and a mac cat back along with a K&N FIPK Cold Air Intake. I plan on eventually putting a Kenne Belle or Whipple in the car when it is paid off in 2 years.
I also ordered the GMS PRO C.O.P. Setup and some new NGK V-Power Plugs.
Did you know there's over 435,000 tobacca an' alcohol related deaths last year? You know how many people marijuana killed? One. One dumbass who tried to hackysack a tarantula... -Rusty, from Squidbillies
Old April 9th, 2010, 05:00 PM   #2
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Stock fuel rails are fine for performance, especially at your power levels. Aftermarket ones just look better.
Probably don't need that big of an injector on an N/A motor. I'd say for a h/c/i full bolt on car it'd probably be fine with some 30 lb'ers. If you're SERIOUS about putting the pd blower on there some day then it's not going to hurt to put in 42's now, you'll just have to get tuned for them.
Do the Right Thing, Cook. ~Zip.
Old April 9th, 2010, 05:03 PM   #3
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
+1, rails are a waste at that level. Just look pretty.
And another +1, unless your going boost you don't need 42's. But if it is in the back of your mind, then get them encase. You don't want to buy one injector then have to sell them back later when you build up with boost.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 9th, 2010, 05:05 PM   #4
jake1191's Avatar
Im serious about the blower. In Fact a few family members are picking it up for a graduation present in june. Then i just have to resist installing it.
As long as im doing the injectors i should probably grab a MAF correct?
On another note are trick flow heads decent or is there something different and better?
Old April 9th, 2010, 05:16 PM   #5
iTrader: 7 reviews
You might be serious about it now, but plans change in two years. Just do the 42's now. If you end up not needing them they are easy to resell.
You don't need a new MAF unless you're pegging your old one.
4v heads outflow TFS heads all day but that's a whole 'nother story. There's a debate going on in these boards right now as to whether or not the TFS heads are worth the price tag.
Old April 9th, 2010, 05:28 PM   #6
jake1191's Avatar
Well if they are a direct bolt on to a 2v block(i know i need the intake manifold, etc.) then i would do it for sure possibly even some aftermarket 4v heads.
Old April 9th, 2010, 05:56 PM   #7
2000 GT
A lot more to it than installing 4v heads. You will need a maf with blower, but not at na yet. You are doing heads and a blower? What about the motor? Sounds like you are about to drop 12k+ on your car. Without touching suspension, and doing all labor yourself.
If you are getting a kb, it is the manifold.
Old April 10th, 2010, 07:32 PM   #8
jake1191's Avatar
The suspension is completely done and was when i bought the car.
The labor will all be done myself and to start off the heads and cams will be done this summer along with the rest of the bolt on stuff and then eventually the KB will be installed.
Threads Similar to: Fixing Up My Fuel and Ignition System
Best Ignition System coffey_5.0 5.0 Mustangs 5 May 15th, 2008 10:04 AM
Ignition system upgrade Dj1123 V6 Mustangs 1 May 14th, 2007 10:33 AM
Upgrading my ignition system... chase 5.0 Mustangs 2 February 8th, 2007 12:54 PM
ignition system noturnormalv6 V6 Mustangs 1 February 2nd, 2007 11:37 PM
