Hood clearance issue - 2001 Cobra vs. 2003 Cobra hood
Old April 9th, 2010, 05:03 PM   #1
Parker Lewis is on a distinguished road
Hi guys,
I am planning for a motor swap in my 2001 GT and will need more clearance under the hood. I know the 2003-04 Cobra hood has more clearance on the underside as compared to the stock 2001 GT hood, but what about the 2001 Cobra hood?
The 2001 Cobra hood seems to be a little taller in pictures as compared to the stock GT hood, but does anyone know if the 2001 Cobra hood has added clearance on the underside like the 03-04 Cobra hood does?
Thanks!
Old April 9th, 2010, 05:06 PM   #2
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
What do you plan on doing to the motor that will need more clearance?
MM + Cleavage member #22
Old April 9th, 2010, 05:13 PM   #3
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
From everything I've read a 99/01 cobra hood is about the same height as a stock GT hood. It's a little bit taller since the GT hood has the liitle dropdown that runs up to the scoop whereas the cobra hood has a reverse scoop style.
And I'm with Dolbs, what are you doing?
Do the Right Thing, Cook. ~Zip.
Old April 9th, 2010, 08:02 PM   #4
I'm putting a 2005 3v in my '01 car. The intake manifold and the t-body sit so much higher. I know of a guy who used a 2000 Cobra R hood with the louvers, it fit nicely. Another guy said the 2003 Cobra hood cleared. I prefer the look of the Cobra hoods much more than the Cobra R or cowl hoods that's why I'm asking about clearance. Thanks guys.
Old April 9th, 2010, 08:04 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
99-01 hood is a reverse scoop hood, same as some of the sixxers
Old April 9th, 2010, 08:44 PM   #6
I understand the 2001 is the reverse scoop, but i'm wondering specifically about the underside clearance. Does the 2001 Cobra hood have the same clearance underneath as the 2003 Cobra? I know it's hard to guess at, but maybe someone has done the swap and can share? Thanks guys.
Old April 9th, 2010, 10:07 PM   #7
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
Well seeming as gt hood doesn't clear my 98 cobra intake and that's the same as 01 intake the 99 cobra hood is obviously a little taller.
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Old April 12th, 2010, 10:23 AM   #8
Thanks for the replies guys.
Stephen, yes that makes sense, if your gt hood didn't fit but your Cobra hood does then i guess it has to be taller, unless the Cobra used shorter motor mounts?
Old April 12th, 2010, 12:03 PM   #9
Telibyte is on a distinguished road
Not sure how tall an 05 3v is, but I put a cobra motor under my 1999 GT hood. Only thing I had to do was take off the throttle cable bracket on the intake and grind it down a little bit.. I can't imagine the 3v being taller than a v4..
Best of luck
Jason
Threads Similar to: Hood clearance issue - 2001 Cobra vs. 2003 Cobra hood
Carbonwire Cobra R Hood latch issue BBMUSTANG V6 Mustangs 16 January 30th, 2010 02:24 AM
2001 Cobra hood Novanutcase 99-04 4 November 2nd, 2008 02:23 AM
2001 Cobra Hood GTSilverBullit 99-04 8 October 12th, 2008 11:23 AM
