LinkBack (1) | Thread Tools |
#1
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
Removing Fuel Rail
Ok to continue with my blowen spark plug i now have the car at a place to work on. 1st step is to remove the passenger saide fuel rail. Any tips or things i need to look at for?
Fire it up, burn it down.
This should help, follow the 3 vids, I know its about spark plugs but he also does the fuel rails.
2003 Mach 1 Procharged 500rwhp club
1997 Mustang Cobra
8.65@84mph
rip that sucker off! When you pull the rail, look for gunk on the injectors and kinda clean them up if you need to. Some people put a grease on the injectors before putting them back in, but you wont hurt anything if you dont.
!FACEPLATED!
fix't
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
'01 GT
Just pops off, I released the pressure from the rail using the schraeder valve first. Also put some rags down to try and catch the excess fuel.
Just take of the nut that holds it in place, then it just pops off, but use the bleeder valve to release the pressure first.
![]() iTrader: 1 reviews
stock driverside/passanger side fuel rails are connected thru a cross over fuel tube. So if you are pulling it completely off the car, you have to take them both off. But its really easy, just 4 bolts holding the entire thing down. Release the pressure through the schraeder valve, and use a fuel line release tool to disconnect it if you need to.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/160590-removing-fuel-rail.html
| Fuel Rail - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | April 11th, 2010 07:35 PM | |
Threads Similar to: Removing Fuel Rail
| Removing fuel line from fuel rail | MyGT | 99-04 | 5 | December 13th, 2009 09:18 PM |
| New fuel line to stock fuel rail barb | nem | 2005 - 2010 | 1 | November 3rd, 2009 09:24 PM |
| I need an 86 Fuel Rail | isaiah48 | 2.3 Mustangs | 1 | March 3rd, 2009 09:13 PM |
| fuel rail | blk98gt | 96-98 | 3 | January 20th, 2008 07:46 PM |
