Cones = Yummy!
YELLOW! 2001 GT VERT
46.496
squeak / moan when turning??
So at parking lot speeds, turning more than 90 degrees I hear a 'moan' from my car, it sounds like suspension 'whine' and only happens when the wheels are turned in for a harder turn.. but (get this) I swear the sound is coming from the rear/trunk...
Anyone know what it could be?
![]() Zombie Killing Club | MM Cleavage Club #7 Specs and Pics in the garage... |
03 gt, 95 740i, 96 disco
rear makes no scene, but if its the front and hasn't been done, theres a service bulletin that shortens the center sleeve inside the bushings of the steering rack mount to suck the bolts in further and tighten it down a bit more, that should help if thats what it is. mine does it but i haven't gotten around to modifying it yet lol.
2003 gt
5.4 32v on the way
Probably have a shot rear. Time to open it up and change the clutch packs, probably would hurt to change bearings while you are in there too if its not a big deal.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#4 | |
Cones = Yummy!
46.496
I also have new shocks and struts so.. not sure what to look for?? really wierd.. And I never heard it till today, and pretty sure I didn't hear it till after there was some rain..
#5 | |
Cones = Yummy!
46.496
i dont, there really isnt as much info about it online as when i searched in mitchel on demand when i worked at a shop lol. its easy to tell from outside, just have someone turn your steering wheel while you listen by the rack, if it is that you either replace the tube in there or shorten it 1/4" and see if it helps. i'd also grease up the bushings to help.
2003 gt
5.4 32v on the way
My car makes that sound, first noticed it while doing a U-turn, my clutch packs are shot. Do a very short burnout and see if one side is lighter than the other, if they aren't even ill put money down saying you need new ones. How about oil in the rear end, do you have the proper amount?
Resident DJ
'01 Cobra Vert.
Is it only happening when the car is "warmed" (driving for a while) up. Or cold & hot?
Cones = Yummy!
46.496
happens warm or cold.. and it really sounds like 'suspension'.. sounds like the springs creaking or something, only really hard turns at slow speeds.. I have new front and rear sway bars.. I wonder if I should lube them not that I think about it the sound I'm hearing makes sense.. like metal/bushing rubbing.. maybe a little silicone spray..
FWIW.. checked my tire pressure today, DF=26, PF=36, DR=35, PR=35... put them all at 36.5 today.. we'll see tomorrow how it handles..
![]() Zombie Killing Club | MM Cleavage Club #7 Specs and Pics in the garage... Last edited by YeloPony; April 10th, 2010 at 09:41 PM. |
Threads Similar to: squeak / moan when turning??
| I have a squeak | vastang757 | 2005 - 2010 | 14 | May 17th, 2009 03:32 PM |
| Need help with a squeak! | 03_StangGuy | 99-04 | 17 | September 17th, 2008 04:58 PM |
| Rear brake moan? | grady | 99-04 | 2 | March 31st, 2008 11:30 PM |
| ? About axle moan/groan TSB | stanglifemike | 2005 - 2010 | 10 | April 3rd, 2007 01:34 AM |
| Squeak Squeak! | DC97Cobra | General Tech | 4 | November 26th, 2005 11:13 AM |
