bad night at the track need some advice
Old April 10th, 2010, 10:20 AM   #1
1999 Mustang GT
BlK99StAng is on a distinguished road
Send a message via AIM to BlK99StAng
so it was my 4th run of the night went to shift into 4th but the gears grinded and the engine over reved, now have a choppy idle, and smoke coming from the exhaust, wats the damage? i checked my oil it seemed good, my car made it home with no overheating, doing a compression check in a few mins, wat should a good compression read for stock sohc 4.6? Thxs in advance
Old April 10th, 2010, 10:27 AM   #2
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
Compression should be in the 170 range. Bet you bent a valve or something related.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old April 10th, 2010, 10:33 AM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
how long were you on the rev limiter when your shift got messed up? whats your limiter set at??
Old April 12th, 2010, 12:34 PM   #4
1999 Mustang GT
i did a test and all but 6 were around 175-185, 6 was at well zero, dropped some oil in
to see if it was the piston ring but no luck, then started to think it was the head
gasket but the other pistons were fine, so i took off the intake manifold and had my gf
hold the ignition while i observed the intake valves and number 6 was not moving, so
yea bent valve
wat do i do from here? can i just replace the valve? or is it better off just dumping
some money on it? wat else should i look for while im ripping the heads off?
any good articles for the how-to of head removal or any tips to make it less painful mainly with timing chain?
Old April 12th, 2010, 12:47 PM   #5
SS Ball3r will become famous soon enough
trick flow heads?
If you have the money i would do that since the heads will be off anyways.
Old April 12th, 2010, 12:57 PM   #6
1999 Mustang GT
yea i was thinking about it too lol, so bent valve seems about right?
Old April 12th, 2010, 01:00 PM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
That would cause it. How much money can you dump? If you want you could just build a new motor from the ground up.
Or if you dont have THAT much, but some TFS heads and some nice cams
410rwhp 520rwtq @ 12.9 psi
Old April 12th, 2010, 01:00 PM   #8
if you have no compression, and the valve is moving, it probabl made contact with the piston and bent and now will not move.
Old April 12th, 2010, 01:07 PM   #9
1999 Mustang GT
any tips on removing the head? mainly for the timing chain? or a how to?
Old April 12th, 2010, 01:35 PM   #10
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
same thing happend to me but mine ended up being a broken valve spring. good luck man w/the fix
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx 92gt short block w/gt40p, explorer intake, 65mm tb, 373 gears, 76mm C&L maf, tubular K-member 14.15 @ 94 (5000' above sea lvl)
Old April 12th, 2010, 01:39 PM   #11
2003 Redfire Mustang GT
before new mods - 13.60@101.40
OH03GT will become famous soon enough
have fun with that - its a bitch and a half
MY GARAGE
MM Bracket Racing Crew Member #2
Originally Posted by Scott2001GT View Post
mmmmm went from wanting to see a chicks picture to dick measuring...MM.com
Threads Similar to: bad night at the track need some advice
bad night at the track..clutch problems please help!! Traidmarx 5.0 Mustangs 20 July 28th, 2009 03:41 PM
went to the track last night. 01GT4.6 Videos 3 July 26th, 2009 11:23 PM
Good/Bad Track Night beefmobile 2005 - 2010 32 October 5th, 2008 05:50 AM
track night. silvergtstang99 Drag 3 April 17th, 2008 10:37 AM
Went to the track last night. jivepepper 99-04 23 October 31st, 2007 10:52 PM
