lose cam follower after cam mod
i hope someone can help me out i just did a cam install on my 04 gt 2v. the car got 18k and some change on it. was letting car warm up and herd ticking noise comming from the last cyclinder on pass side. just didnt sound right. so shuter down and pulled valve cover off. and found the cam follower was lose on the lash adjuster and valve. when lobe is up the follower is not touching cam . when motor is turned by hand the valve and lash seemed to work. from what i can see.
2004 mustang GT
12.5 @115
is you valve returning all the way to the top?
2004 mustang GT
12.5 @115
your lash adjuster may not be pumped back up. I asume you put them in a vise.
it seems to be from what i can see. yeah i did put in vise
when the lobe is up . the follower is not touching cam.
the car ran for about 20 mins . the lash was hard to push down like it was pumped up. what can i do to check valve to see if its bent other than removing the head. thats what i dont want to do. i do all my own work so labor is free thank god. the drivers side is fine . and could it be some how out of time. installed cam gears at 11 o'clock on pass side and 12 o'clock on drivers side. with crank keyway at tdc mark about 11 o'clock
1999 Mustang GT
Do a compression check.......compression low bent valve. Also if you have a bent valve etc you should have a engine miss.
Boost gets you laid
it would be a wise idea to replace that lifter. could have damaged it in the vice or something.. they should pump up in just a couple seconds.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
thats what i did i got a new lash adjuster on way .is there any way to adjust the lash adjuster. i seen a pic with a small flathead in the adjuster. there is no miss in motor the car sounds great. only problem is the lose follower when cam is up. and the loud ticking. is the very last valve on pass side intake. thats the one that is lose
what about degreeing the cams . i dont think you can do it with heads on car if you can how. the cams i installed are trickflow stage 1's with my stock heads changed springs and seals. didnt take heads off . i couldnt afford to change out the heads. i have most bolt on's , on the market. only thing next is to twist it??? hopefully next year i can do that.
2004 mustang GT
12.5 @115
you can only do it with the heads on.It is a little harder when the motor is in the car (not alot of room).Just look in the search box for degreeing cams and you will see tons of write ups.
i live in the pittsburgh area do any of you know were i can get my rear gears swapped out. i have all the parts just need someone to do the work for a reasonable amount. i dont have the tools to do it and dont want to mess anything up. whats the average cost on labor on a job like that. like i said i have all the parts, bearings to cover??
does degreeing really make a big differance.
#15 | |
Moderator
2012 300a gt auto
12.10@116
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
I live in beaver county. center twp.
Threads Similar to: lose cam follower after cam mod
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 10:36 PM |
| 289 cam vs 351 cam | Kenn | Classic Mustangs | 11 | May 5th, 2008 01:20 PM |
| N/A Cam and Blower Cam ??? | StuTheMusicEngineer | 99-04 | 1 | March 3rd, 2007 04:35 AM |
| E cam or F cam horsepower and 1/4 mile time questions | GreyGhost | 5.0 Mustangs | 1 | August 21st, 2006 06:25 PM |
