Vortech guys, where di you run your bypass vacuum??
Old April 11th, 2010, 05:44 AM   #1
01MGGT has a spectacular aura about01MGGT has a spectacular aura about
Where did you guys run the vacuum line for you bypass valve? Mine is run of the fuel pressure sensor on the driver side fuel rail but was curious if there was a better place? I also want to run my boost gauge to this same sensor. Will this cause any issues?
375hp 380tq
Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper
vids
http://www.youtube.com/user/01mggt
Mineral Grey Club member #14
Military Crew E-4
Predator Crew Chief Holloman
Old April 11th, 2010, 10:30 AM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
I have my bypass tee'd with the frps line. But my line for vac/boost gauge i have by itself. Since my module is inside the car i figured that much line could distort the signal or cause a delay.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 11th, 2010, 02:49 PM   #3
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
mine is set up all off of the frps vacuum... but i have heard that you do not need the vacuum tied into that. I was told it can cause some kind of "burp" or back pressure on the vacuum but im not sure on that...
Old April 11th, 2010, 02:57 PM   #4
See that's why I am thinking of moving mine, it almost seems like my bypass valve is slow to react with the vacuum being there. I may move it somewhere more direct to the manifold and a shorter distance.....
375hp 380tq
vids
Military Crew E-4
Threads Similar to: Vortech guys, where di you run your bypass vacuum??
vortech mini bypass? bottlefedbullitt01 General Tech 3 September 22nd, 2009 12:36 PM
which would be a good sounding bypass valve for a vortech SilverGT04 99-04 12 September 15th, 2009 12:35 AM
vortech maxflow racing bypass ajm 99-04 4 February 14th, 2009 03:37 PM
stock vortech bypass bransdaman78 General Tech 12 April 13th, 2007 12:32 PM
