#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
*goes to look at belt im running*
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
#22 |
ill have to get the numbers tomorrow. Cant seem them in the garage. Shit is too dark. lol
#23 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
lol ok man. What about that tab?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#24 |
what are you saying again about the tab?
#25 |
BYAHHHH!
2001 Mustang GT
13.874
on some of the tensioner i read there is a tab to be grinded off
#26 |
just went and looked and even if my belt was 3" smaller, there is not tab or anything that would be in the way. We MAY have different style idlers from windsor to romeo. Not sure though.
#27 |
BYAHHHH!
2001 Mustang GT
13.874
thats what I read. The 01 were different!
#29 |
i still dont think thats your problem. I would put a belt on and turn it over a few times or just let it run for 30 seconds or whatever to get the belt running where it is going to run and then just check it all out. SOMEWHERE, you will find SOMETHING out of align!
In your 2nd pic, i notice that it looks a lil off if you try to look at blower pulley, alt pulley, and water pump pulley but it may just be due to the angle of the pic. If you hover over the blower you will be able to tell if its straight or not. If it is, then id move to the 2 idlers.
#30 |
well thats something you will have to check on site to see if it is causing the problem. This type thing is an on site ordeal. Wish you were near! lol.
Never knew that idler issue. Id check into it more now after reading that.
#31 |
BYAHHHH!
2001 Mustang GT
13.874
yeah man. I'll call Procarger tomorrow for sure!
#32 |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
I had to run a washer between the timing cover and the blower bracket on the lower bolt and stud of my procharger setup to basically shim the blower to line up correctly. I shredded 2 belts before I figure this out and corrected the angle. Every car is different and will need different amounts of shimming in order to properly line up the blower pulley with the rest of the system.
Note: The blower pulley only needs to be very slightly mis-aligned to shed the hell out of some belts. |
#33 |
2000 GT
Yeah somethings out of wack. My expensive ass kit from KB didn't align right either. And the tab is to get the belt tighter if you grind it off. Makes it easier to put belt on... but your problem is alignment not belt tightness. Something is either rubbing, or out of alignment so it jumps a rib then shreds it.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#34 |
BYAHHHH!
2001 Mustang GT
13.874
Well I looked at my blower idle and it is CROOKED! I was like shit! lol. And it's hard to eye ball the blower to the idle! Is there some secret besides the "eye balling" trick. I mean yeah I can shim it but if I cant tell if it's aligned there isn't a point.
Thanks dudes...but I still need to figure this out!
#35 |
2000 GT
Look at the belt angle, if it is at all twisted. If the idlers are off then it is pretty obvious. But if it is subtly off then look if the belt is angled or twisted at all. Thats how i found my problem. I have shredded 2 belts for not being aligned, and one because the belt wasn't tight enough and jumped a rib (was probably when it wasn't completely dialed in alignment too).
So get a small flat edge and see if you can find a twisted angle on the belt. If it is not eye ball able
#36 |
BYAHHHH!
2001 Mustang GT
13.874
ahh this sucks! lol I just want to drive it! I got a new belt. Same size, the one I need anyways. idk when We will get to it. Maybe weds. I want someone to check it over before I drive it
#37 |
BYAHHHH!
2001 Mustang GT
13.874
FUCK! I worked on the blower today and I had the pulleys aligned(to what I could see) but the idler was crooked so I got that right and then the blower pulley hit the alt housing! SOB idk anymore dudes
Threads Similar to: Two belts shredded
| Seat Belts | Codeman | V6 Mustangs | 23 | January 29th, 2010 03:44 PM |
| Belts not aligned?? | Chuluota5.0 | 5.0 Mustangs | 2 | November 20th, 2009 11:14 PM |
| s/c belts | bottlefedbullitt01 | 99-04 | 9 | April 9th, 2009 07:49 AM |
| k/b sc belts | new2mustangs | 99-04 | 17 | October 28th, 2008 07:11 PM |
| Shredded cam gear, what caused it? | 99v6stang | V6 Mustangs | 28 | January 29th, 2008 12:13 PM |
