1999 Mustang GT
Fuel pump problems
ok. i just rebuilt the 4.6 in my 99 GT, got it in the car, cranked it until i got oil pressure, went to start it and no fuel. i listened for the pump to come on and nothing. whats wrong with it?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
check the fuel pump fuse under the hood. then check the red relay button in the trunk.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
1999 Mustang GT
I checked the inertia switch in the trunk and it is fine. i will try the fuse next. thanks
should be a small 20 amp (i believe) under the hood.
1999 Mustang GT
ok. if thats not the problem what else would you suggest?
next would be to check to be sure ALL of your wiring harness is hooked up. The car was running before you pulled the motor correct?
1999 Mustang GT
yup...ive plugged in every plug that i unplugged under the hood
besides not hearing the fuel pump, what is telling you that you arent getting fuel?
1999 Mustang GT
there is no fuel pressure at the fuel rails and none coming out of the injectors when i crank it
got gas in it? lol hey, you never know! lol.
1999 Mustang GT
haha yeah that was the first thing i checked lol
well check the fuse. Other than that, dunno.
1999 Mustang GT
the fuse was in good shape, so i dropped the tank, took the pump out, hooked it up to a 12 volt power supply and nothing. after reversing the leads i finally got it to break free and start working. i went ahead and ordered a new pump. hopefully i can get my car to start now lol.
another question. besides letting the new motor run at around 2500 rpm's for 30 minutes, what else should i do as far as breaking it in? how should i drive it for the first 1000 miles? |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Drive it like you stole it
![]() JK I just wouldn't goose it to 6k rpm for the first 500 miles, then change the oil and drive it like that again for another 500, change the oil again, and then you can drive however you want
Do the Right Thing, Cook. ~Zip. |
Threads Similar to: Fuel pump problems
| Fuel pump problems | skullhead | 5.0 Mustangs | 0 | March 22nd, 2010 09:10 PM |
| 02 fuel pump problems | medusa | V6 Mustangs | 1 | February 12th, 2009 07:05 PM |
| Fuel pump problems | MIGHTYJO3YOUNG | 5.0 Mustangs | 1 | May 22nd, 2008 09:25 PM |
| fuel pump problems | roush 2001 | 5.0 Mustangs | 4 | March 16th, 2008 11:42 PM |
| Fuel Pump Problems | bigbadtalontsi | 5.0 Mustangs | 5 | March 30th, 2007 04:50 PM |
