NA
02 Gt Procharged keep throwing bottom end bearings
I have a 02 gt that is on its second stock motor its procharged with 42.LB injectors,throttlebody and manifold also headers and exhaust. what is something someone did to have a strong reliable motor? obviously i need some forged internals but i dont want to go to the extent of building the whole thing for a spendy price since i just dropped two grand in it for a motor.
Hooo Ha Ha
MMR makes built shortblocks that come pre built so you can bolt your heads on and go. That would be your best option.
![]() 410rwhp 520rwtq @ 12.9 psi |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
its just happening. how many rpms are these motors seeing?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
12.73@111.36
How much boost? What is the rwhp?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
NA
yesterday was about 5 to 6 maybe for a pull then the rest was lower then i got to a stop sign and it started knocking with 4 or 5 pounds of boost
how were you at a stop sign and in boost? Shouldve been in vacuum if you werent at WOT.
NA
If anyone wants to buy the gear with a spun rod bearing message me it runs but knocks a little has 71k miles ran amazing yesterday till i pinned it once a little then motor knocked Nitrous has never been used on this motor by the way
2002 mustang gt-auto, leather,6 disk changer,mach sound system 18 inch wheels rear deep dish parts rocharger and intercooler,accufab throttle body,manifold,zex nitrous,shift kit,baer brakes,drilled and slotted rotors,lunar cluster and pillar guages, carbon fiber hood,![]() ![]()
2001 Mustang GT
how did you blow it up running 5 psi?
2001 Mustang GT
you didnt get it tuned n just ran it?
im still trying to figure out how he got 5 pounds of boost sitting at a stop sign
I'm trying to figure out why he has a CF hood.
where did you get your gauges from, I want them.
K&N CAI DiabloSport Predator tune Bassani o/r x pipe Borla cat back Eibach Pro kit Nitto 555r on Cobras |
nm, I found them... and are expensive......
02 Mustang GT
9.91@133
I can make boost while at a stop sign
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
yeah i know that but im speaking of in a random day you just decide to make boost at a stop sign. I wonder if i could to. If i just hold the gas down it may.
April 2012 ROTM
spray and boost on a stock bottom end? thats a recipe for disaster...im not buyin that its never been used...another true blue stang bites the dust...cue TAPS
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
That's what I was thinking. I've seen one other car with a blower and nitrous on stock bottom end. He blew it up on the first pass with spray....it was on 8lbs and a 150 shot.
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
12.73@111.36
I'm just curious as to why anyone would think a stock bottom would hold up to both spray and boost. 8 lbs of boost and a 150 shot is what? Near 500 rwhp? Duh.
2001 Mustang GT
i tihnk it will blow any stock bottom end up lol on the first shot of nitrous
NA
If it blew when i used it i wouldnt be on here asking about it would i....Didnt run nitrous. and let me say it slower for you. I punched it to 5 or 6 thousand (RPM) if u dont know what that means i can help u with that too and then When i GOT to the stop sign. Just draw a picture k.. a car moving right going goin goin then it GETS to a stop sign then the person in the car Hears THE CAR Knocking. anyways. yeah was dissapointed that i only boosted about 5 or 6 pounds and the bottom end couldnt take it. and yes its tuned it came with the procharger
Threads Similar to: 02 Gt Procharged keep throwing bottom end bearings
| 9"Rear end, small or large bearings? | Remo | Classic Mustangs | 0 | July 1st, 2009 03:21 AM |
| Top End vs Bottom End | triggers68 | Classic Mustangs | 7 | March 18th, 2009 10:46 PM |
| Bottom End | bartee25 | 99-04 | 4 | September 9th, 2008 01:10 AM |
| front wheel bearings or rear end noise? | jasons_98gt | 96-98 | 2 | April 6th, 2008 09:20 PM |
| What's The Bottom Line On The Bottom End? | SKRAPR | 2005 - 2010 | 48 | November 25th, 2007 11:38 AM |
