2001 Mustang GT
ford gt fuel
anyone know where you can get a pump for the cheapest? ford dealership says over 200$
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Google search it "GT supercar fuel pump"
I know right off hand that lethal performance has them
Do the Right Thing, Cook. ~Zip. |
2001 Mustang GT
how do i need to do the fuel pump setup. im running a procharger. it looks like theres two pumps?
2000 GT
You don't need 2 pumps unless reaching over 450 hp. I ran a single pump (with pprv delete) and BAP (wiring upgrade) to 500 hp. Buy submersible gates hoses, and don't cut them (prevents kinks). You will have the hose go from the pump, to the hat. Pretty simple with a single pump. And drill holes in the front of the basket, not the back.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2001 Mustang GT
so what shuold i do to just run under 450
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
2001 Mustang GT
What exactly do i need to run just one? its plug and play? i know its been discussed before but what im getting it is what parts to i need to run it? pprv deletes or wiring upgrade?
Gates submersible fuel line - costs liked $30 at napa, 2 hose clamps, 2 female spade connectors, and youre good to go.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I got my pump at Lethal
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
2003 mustang
7.48x1.56=11.67
rpmoutlet.com sells them also. You should be able to pick up a single for around 130.
I cant believe the focus pump sells for 200. Thats crazy.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
#12 | |
My line was $21 from O'Reillys.@OP you'll also need a fuel line disconnect tool to drop the tank. Also you'll need a little socket or wrench to take the cap off the basket. They're like 4mm or something like that. You can use a pliers if you have to though, it's not like they are sunk in there real tight. I just prefer to use the right tool if I can.
2000 GT
Lethal also sells the hose if you buy the pump there. I found it online from some weird dealer for like 22 bucks or something like that... if only i knew (found it after i bought it).
Threads Similar to: ford gt fuel
| Ford GT Fuel Pump | GTermi | 99-04 | 42 | November 29th, 2009 03:17 AM |
| HELP Ford GT Fuel Pump | GTermi | 99-04 | 17 | September 6th, 2009 10:30 PM |
| Need to know-ford gt fuel pump | DickH | 99-04 | 11 | June 8th, 2009 12:03 AM |
| Ford gt fuel pump? | DickH | 99-04 | 1 | February 27th, 2009 10:16 PM |
| Ford GT fuel pump? | supercharged03gt | 99-04 | 23 | February 10th, 2008 11:39 PM |
