Home made heat shield for CAI
Old April 12th, 2010, 07:43 PM   #1
2003 Mustang GT
Arlander is an unknown quantity at this point
Ok, so I bought a Spectre CAI, the one that the filter just sits in the open without a heat shield or fender connection, from Autozone back when I first got my Mustang before I started to get a clue as to what was what....
NOW I'm trying to figure out a way to fix the setup so that it's not drawing hot engine compartment air. I asked Spectre but they do not make a heat shield for it. I really don't want to buy a new setup sooooo.....
I'm thinking about trying to modify the factory OEM plastic box that went around the stock filter and into the fenderwell to fit. It is just a little bit too small to fit the current filter so I was thinking about cutting a V shape on the fenderwell side to open it up for that filter. So it would mostly be surrounded by the stock plastic filter box and would have the inlet back into the fenderwell with just a slight V cut out of it when finished. Does anyone see any problems with this or maybe some better ideas? (Yeah, I know I was an idiot from the start...)
2003 GT, Auto, Vortech V1 T-trim, AFM Powerpipe, 3.73 F.R. gears, Comp Cams 262AH, O/R H-Pipe, Flowmaster 40 Series, Trick Flow UDP's, BBK 78mm Intake, Transgo Shift Kit, Mishimoto T.C., Eibach S.S.
^^^BOTH OF MY RIDES!^^^
Old April 12th, 2010, 07:49 PM   #2
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
Our cars don't need heat shields like the 5.0's
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old April 12th, 2010, 07:52 PM   #3
2003 Mustang GT
Still, wouldn't it be better to draw the air from the fenderwell instead of the engine compartment?
Old April 12th, 2010, 07:58 PM   #4
Garrett's Avatar
1998 Mustang gt
Garrett is infamous around these partsGarrett is infamous around these partsGarrett is infamous around these parts
Send a message via AIM to Garrett
^ I would think so.
myspace.com/garrettstarnes
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
Throtle Body spacer.
More to come!
Old April 12th, 2010, 08:23 PM   #5
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
I've seen them made out of those rectangular small office trash cans before.
Old April 12th, 2010, 08:27 PM   #6
2003 Mustang GT
LOL, I never thought of that but I guess it should probably work. I was just gonna use the stock plastic box because it already has the screw holes lined up with the body.
Old April 12th, 2010, 08:29 PM   #7
dannyboy281's Avatar
2003 Azure Blue Mach 1
5,000 miles on the ODO
dannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to all
just use some sheet metal and fab it up it will look good just sand the edges so you dont get cut when working on your car
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
Old April 12th, 2010, 08:44 PM   #8
2001 Bullitt
12.25@110.4
here's a trashcan heat shield a guy did for a Lightning:
$3.95 DIY Heat Shield for Cold Air Intake - The National Lightning Owners Club Inc
Old April 12th, 2010, 10:08 PM   #9
2003 Mustang GT
That's cool, if my factory plastic housing project doesn't work out I'm gonna move onto trying that.
Ok Dannyboy, I just have to say, whoever the hell that chick is on your sig is criminally f'n HOT!!!
Threads Similar to: Home made heat shield for CAI
Clutch noise when cold - sounds like a loose heat shield To D Lake 2005 - 2010 27 April 7th, 2010 11:15 PM
Home made CAI kit????? is it reasonable??? 02GT89 99-04 25 April 4th, 2010 11:39 PM
Costum made heat shield vsix V6 Mustangs 5 February 19th, 2010 05:52 PM
Easy Mod: Heat Shield Paint yelsir06 Visual 6 July 22nd, 2007 01:00 PM
HOME MADE CAI BLACJAC 2005 - 2010 4 April 2nd, 2007 07:27 PM
