problems
i have a 2004 mustang gt that has a few bolt-ons. i have hi-flow fuel rails, 32lb. injectors, 75mm t/b, cai, and slp loudmouth cat backs. the car does not run well at all just wondering if there is anything i can do to solve this problem? i have a diablosport predator tuner but dont really know wat to set it at. any ideas would be helpful. thanx
to mmDamn bro, were do i start their could be so many things wrong. What exactly is it that it does? |
well first of all when you start the car it revs up to about 2400 rpms and thats where it idles. im thinking that is from the t/b that i put on. but the bad thing is when i upgraded the fuel system it acted like it was flooding out all the time. when you drive it doesnt have any power and it sputters allot. i have long tube headers and o/r h pipe and am going to get a new manifold soon. should i try to get it dynoed or can i just tune it with the tuner i have?
Holy shit it idles at 2400: o
I would first check were the idle screw on the throttle body is set at. With the car off, remove the intake tube, and see were the butterfly on the throttle body is at, it should be almost closed. It might also be your IAC Is there any CEL? Last edited by 01KnightRiderGT; April 15th, 2010 at 08:35 AM. |
2004 mustang GT
12.5 @115
Put your stock inj. back in, you don,t need 32lb. inj. with your mods. Inj. will not give you horse power they allow you to stay in a afr when your mods make too much horse power for the stock ones.
the idle screw is the first thing i checked but that wasnt it. do you guys know what size stock injectors are? i accidentally threw the old ones away. and do the high flow fuel rails help at all?
#7 | |
^ that also |
Resident Bubblehead
bigger injectors and high flow fuel rails won't make more power, they just support it. the high idle could be your IAC, sputtering could be becaues of the long tubes. i had some issues with mine when i got them put on. i got a good dyno tune and it fixed the issues for me. are you throwing any codes/ CEL?
the stock injectors are 19lbs
how much horse power are the stock injectors good to?
Resident Bubblehead
the stock ones are plenty to support your other mods. i'm making 275 hp/ 310 tq on stock injectors and not even close to maxing them out. you'll be fine for a while unless you start playing with spray or FI...
2001 Bullitt
12.25@110.4
Not on an '04....
![]() I believe the '04 had 21lb injectors stock. OP, I would almost bet that those injectors are your problem, especially if you're not running a custom tune with them. You can change the injector size in the SCT, I would guess you could do the same in the Diablo, but it's just simply too much injector for your mods. The engine just can't use that amount of fuel, and can't back the fuel pressure down enough to make it run decent without it going all crazy. The amount of horsepower isn't really a set number, it depends on a bunch of factors, but with 21lb injectors, you could run well over 300rwhp, which is every bolt-on with cams. The only reason to change injectors or MAFs on these cars is when you run out of fuel for your mods. If you run too big of an injector, you're usually stuck with a car that won't idle well, low rpm power sucks, and generally just makes a car that's not happy, especially down low. |
no i didnt get a tune for the big injectors yet i might try to find some stock injectors for it tho
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Have a tune for the bigger injectors or did you just slap them in and call it good? If you dont have a tune for them im willing to bet money thats your problem.
24lb injectors on the '04....
![]() ________________ JLT CAI, Accufab 70MM TB/Plenum,Xcal 2/BamaChips Tune |
i have a set of stock yellow 19# injectors that i'd be willing to sell if you're interested. PM me if you want to buy them.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
I ran 42lb injectors with my car before the blower with jsut bolt on's and cams. All in the tune
I say throttle screw is the cause if you already selected the injectors int the tune. You should check your TPS voltage. Should be around .96 with the throttle closed.
![]() 375hp 380tq Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper vids http://www.youtube.com/user/01mggt Mineral Grey Club member #14 Military Crew E-4 Predator Crew Chief Holloman |
2001 Bullitt
12.25@110.4
Threads Similar to: problems
| So many problems | GT33 | 2005 - 2010 | 22 | May 30th, 2009 01:17 AM |
| More Problems | 330CubeGt | 96-98 | 3 | February 15th, 2009 01:01 AM |
| 5.0 Problems | Monk | 5.0 Mustangs | 0 | August 31st, 2008 09:37 PM |
| Problems | 98blackonblack | V6 Mustangs | 1 | January 2nd, 2008 02:51 AM |
| Help! Several Problems With '99 GT | menedu | Modular Mustangs | 20 | November 17th, 2006 10:57 AM |
