410's and a kenne bell
Old April 15th, 2010, 11:08 AM   #1
competition orange's Avatar
2004 mustang gt
competition orange is on a distinguished road
i currently have 410's and recently bought a used Kenne Bell,should i just put my stock gears back in?I think 410's are goin to be a to much.I would like to hear from some of you guys that may be runnin 410's and a kenne bell. I know with the 410's i will be overspinning the Kb way before i hit redline and don't want to destoy it.
Old April 15th, 2010, 11:13 AM   #2
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Why not just try the 4.10s and see how you like them. It's kinda pointless to do all the work putting stock gears in and then deciding you want to step back up to 3.73s or something.
And I don't see you having problems with overspinning the KB unless you're doing top speed runs. If you're racing you're going to shift at 5600-5800 no matter what gears you have. The only difference is you'll be revving a little higher in 4th gear.
Do the Right Thing, Cook. ~Zip.
Old April 15th, 2010, 11:13 AM   #3
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
you wont be over spinning it...6k rpm is 6k rpm...regardless of how fast you get there
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old April 15th, 2010, 11:14 AM   #4
iTrader: 7 reviews
This doesn't make sense. The KB will only spin as much as your engine does. You could have 2.73s in your car and the blower will spin just as much at redline as it would if you had 4.56s
Old April 15th, 2010, 11:15 AM   #5
April 2012 ROTM
+1...thats what I was getting at
Old April 15th, 2010, 11:17 AM   #6
iTrader: 7 reviews
Haha, you just beat me to it!
Old April 15th, 2010, 11:25 AM   #7
2004 mustang gt
maybe this will clarify my statement,this is straight from kb install manual
keep supercharger rpm(drive ratio x engine rpm =supercharger rpm)to max 18000rpm
for example 3.27 X 5500= 17985rpm's
so if this is the case then with my 410's i will hit the 18000max rpm's at 4390 rpm's
Old April 15th, 2010, 11:35 AM   #8
iTrader: 7 reviews
I'm sure they mean the drive ratio of the supercharger, not of your rear end.
Old April 15th, 2010, 11:41 AM   #9
mell0's Avatar
2002 Procharged GT, STR
12.503 @ 113.08
mell0 is just really nicemell0 is just really nicemell0 is just really nicemell0 is just really nice
Send a message via AIM to mell0
+1 on drive ratio of the supercharger. your rear end gears have nothing to do with how fast the supercharger is spinning. i know my procharger's drive ratio is 4.10 which is also coincidentally a common rear end gear ratio.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Old April 15th, 2010, 11:43 AM   #10
iTrader: 7 reviews
Here, look at this for drive ratio info. It's on page 4
4.6 Kenne Bell Tech
Old April 15th, 2010, 11:50 AM   #11
2004 mustang gt
i know it sounds crazy but thats what it said and its for the rear end not the drive ratio of charger.it has a list of the different gear ratio's and rpm's =max charger rpm's.like you said the rpm's if there at 6 there at 6 and the sc rpm's doesnt change and later in the explanation of the gears it says that 373's are the best for 1/4.so oh well i'm not worring about the max rpm cause that doesnt seem right.
Old April 15th, 2010, 11:54 AM   #12
2004 mustang gt
4.6 Kenne Bell Tech
that makes alot more sense,thanx
this kit i got is 5 yrs old an the instructs i got are totally different then them cause mine clearly states rear end gear ratio an then the text is basically the same minus the crankshaft pulley part,oh well thanx for the help
Old April 15th, 2010, 12:06 PM   #13
iTrader: 7 reviews
They probably say 3.73s are the best because of the instant power the KB makes
Old April 15th, 2010, 12:45 PM   #14
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
just try the gears and see if you like them, personally I think they are too steep for a pd car with stock dia. tires
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old April 15th, 2010, 02:31 PM   #15
Ke^in's Avatar
Ke^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to all
I wouldn't go with a higher gear other than 3.73s unless there are some good suspension mods, and you have something stickier than a 555r.
I like to go to Subway because the women there have to make ME a sandwich.
Old April 15th, 2010, 02:34 PM   #16
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
Can the 4.10's. My 3.90's were even too much when I had the KB. The KB will give you plenty of TQ. I would go 3.73 or 3.55 but go ahead and try the 4.10 at least, everyone has there own opinion
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old April 15th, 2010, 02:56 PM   #17
mell0's Avatar
12.503 @ 113.08
i think i know what they mean by overspin the blower. they are probably talking about the 1/4 mile, and with the blower and 4.10s, you'll be at the top of 4th and if you don't shift to 5th you'll overspin it (and go past your redline). just a thought.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Old April 15th, 2010, 05:26 PM   #18
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
you could always get a taller tire to throw it off some
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old April 15th, 2010, 07:47 PM   #19
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
410's you will be all over the place in first 2 gears (if you have good tires); hell i was with 3.73s at that boost level (but had stock suspension at the time).
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 15th, 2010, 08:04 PM   #20
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
A buddy of mine has a 94 camaro with a 383 stroker and a paxton charger on it built auto trans and 4:10s in the rear. He says that he is just spinning the tires like nobodies business.... but then again he has no tread. He was thing about going to 3:73s because he would just wind that thing up so quick and he kept complaining that he wasnt getting good traction and he lost alot of his top end speed. Meaning he isnt going to 160+ anymore... I dont run with him he is one of the stupid people that just has no respect for others on the road.
Threads Similar to: 410's and a kenne bell
Kenne Bell 2.1L s/c bbk03gt24 99-04 2 August 12th, 2009 08:51 PM
Kenne Bell 2.6H vs 2.8H 05mustang_TT_charged 2005 - 2010 25 June 7th, 2008 10:01 AM
Kenne Bell ??? silverstang0988 General Tech 17 April 7th, 2007 11:38 AM
Kenne Bell 03blownmach1 99-04 11 June 28th, 2006 01:04 AM
