351w into 99-04 Mustang
Old April 15th, 2010, 05:20 PM   #1
jruppert is on a distinguished road
Greetings from Michigan... I am new to this forum, so I will start off with hello. I have been searching this forum for information regarding doing the 351w swap. I have found some interesting posts so far but my situation is a little unique.
First off, I currently own a 94 Mustang GT with the following mods... 351w, AFR 185's, TFS cam, Edelbrock RPM intake, 75 mm throttle, 77mm Pro-M, Tremec TKO, Tweecer RT.
I have been interested in purchasing a convertible. I like the 99 and newer style. So my thoughts were to purchase a 99 and newer and swap my parts into the 99. The difference would be that I want to go with a 7r40w from a v6 for boltup purposes.
My biggest question is to decide how to go about fuel injection. My first thought was to use the harness from my 94. Then I go to thinking about the wiring in the 4.6. Has anyone tried fabricating the sensor plugs to accept the pushrod? I dont see how it would be too difficult seeings that you are still working with 8 cylinders and the computer should adjust especially with using a tweecer. I thought maybe with this route it would be easier to run the digital odometer and keep pats. Any thoughts to this?
Old April 15th, 2010, 05:23 PM   #2
Penetration before detonation
suprajay79's Avatar
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
suprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to all
Hm.
Given a few things, it might make it a bit tricky.
I'd recommend sticking with the 94 computer. There are a few variables that would make using the 99-04 computer a bit tricky.
Originally Posted by 65eatsrice View Post
what better way to be woken up
Originally Posted by Jakashh View Post
a blowjob
Military Crew E-5/SSgt
White Mustang Crew Member #5
315s Crew Co-Founder
Old April 15th, 2010, 05:29 PM   #3
I am sure that there is a lot more that the computer controls especially with alternator, a/c, etc. It was just an idea that I thought of. I have also thought that maybe I should just stick with another 94-95. The 99-04 is just so tempting though.
Old April 15th, 2010, 05:34 PM   #4
suprajay79's Avatar
2001 Mustang GT
You would have a hell of a time trying to make a modular engine computer work with a pushrod engine. Most of the interior and gauges are the same from 94-2004, so putting in a 94 computer wouldn't be too much of a stretch IMO.
a blowjob
Old April 15th, 2010, 05:48 PM   #5
Does anyone know if the 7r40w harness in the 96-04 has the same pigtail as what the 94-95 would have?
Old April 15th, 2010, 11:14 PM   #6
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
their simular but at a minimum you'll have to change the pin orientation. best bet is to call Alan (dirty dog link in my sig.) he'll let you know what you need. oh & its a 4r70w in the newer cars, you have an AOD-E.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old April 16th, 2010, 12:12 AM   #7
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
There is a guy on here with a 351 with a c4 swap. I cant remeber his name right now tho!
Old April 16th, 2010, 01:00 AM   #8
suprajay79's Avatar
2001 Mustang GT
Mustangmatt96 I think, if that's the same guy you're thinking of.
a blowjob
Old April 16th, 2010, 05:34 AM   #9
I know the 94-95's came with the aode but I want the 4r70w for the lower first gear plus they can handle more horsepower.
Old April 16th, 2010, 08:52 PM   #10
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
I mentioned the trans models to help explain the diffrence in the plug orientation, I know why you'd want to change (ie. gear ratio, better trans components, etc)
2012 300a GT auto
Threads Similar to: 351w into 99-04 Mustang
99 v6 mustang 351w and 8.8 rear end swap Th3 Mag1c Man V6 Mustangs 16 October 19th, 2010 11:08 AM
351w in 68 mustang. help w/ HEADERS Kriz818 Classic Mustangs 21 February 11th, 2010 07:34 AM
advice needed for putting a 351w in a 65 mustang 65mustangmuscle Classic Mustangs 5 October 3rd, 2009 10:28 PM
Mustang 351w Problem -Joeyy- 5.0 Mustangs 43 September 16th, 2008 04:02 PM
