meth injection - Page 2
Old April 16th, 2010, 07:22 PM   #21
yellow04GT's Avatar
2004 mustang GT
12.5 @115
yellow04GT is on a distinguished road
Ok my .02 I run meth on my car.My tuner is very conservative and does not blow his customers cars up (even when we beg him). My non meth tune is very safe however you never know. If it is a very hot day and a bad tank of gas it could happpen. So I run a meth tune that is a little more aggressive and would probably be fine if the pump took a turn for the worse. But when you feel the intake after a pull on the dyno and it is cool to the touch you know it is safer than running a street tune without it. As far as gaining more hp from the cooler intake temps my sensor is in the maf meter and I don't think it would like me spraying it before the meter. Some of our cars have the temp sensor that is in further down stream. But mine is in the maf.Once again it sucks to be me!
Old April 16th, 2010, 08:24 PM   #22
Trick Tuners's Avatar
KB'd GT
what about the potential non-homogeneous distribution issues? That is my biggest issue with meth. If there was a better direct injection kind of thing that would be way better than trying to spray meth into a manifold designed to only flow air.
Old April 16th, 2010, 09:11 PM   #23
yellow04GT's Avatar
2004 mustang GT
12.5 @115
trick tuners-isn't that the same problem with drawing gasoline down a carb or pushing nitrous and fuel through a single nozzle? I am not that worried about it like I said I only use it as an added measure I don't gain much with it.
Old April 17th, 2010, 01:21 PM   #24
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Carbs and their corresponding intake manifolds are designed to flow fuel. I don't know n2o setups though so can't say anything there.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 17th, 2010, 08:24 PM   #25
yellow04GT's Avatar
2004 mustang GT
12.5 @115
Sorry I thought you were refering to distribution, if it is distribution.Then moving air or fuel from a single point and distributing it evenly to eight different points is difficult to say the least.(I agree with you).But I am not sure I would worry about how much meth gets into each port. The meth is a fine mist speayed into a rapid stream of air rushing past the nozzle. Just my thoughts.
Old April 17th, 2010, 08:43 PM   #26
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
Water/Methanol Injection - Chemical Intercooling For You Boosted Engine - Hot Rod Magazine
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old April 17th, 2010, 09:01 PM   #27
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
I dont think it would be an issue with a 150psi pump and a reasonable size shot.
Personally I only see good things from it and am a fan of using it on any boosted car.
Where alot of people go wrong imo, run an agressive timing curve and take fuel out to compensate for the meth. This is why I run a 350ml nozzle and 50/50 mix(I mix my own stuff). I have not taken out any fuel in the tune and run 18* timing...which is good for 93oct alone. What I do is run more boost and make power this way.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old April 17th, 2010, 09:31 PM   #28
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
One thing to keep in mind. I have ran methanol injection for many years(mechanical inj) and one thing for sure- methanol does not like aluminum. it will eat it up.
I am not a fan of methanol injection because I think the problems that come with it on a street car is not worth it, you have to be on top of it constantly(maint. wise). for a track car it may be the ticket thou
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old April 18th, 2010, 05:43 PM   #29
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Mr freeze?? I ran that kit at first but did not work with my setup. No real maint issues here. Have pvc pipe in between maf an intake and which is where I spray. The only problemb I have had so far is my snow pump went out after 2 yrs of use...I bought it used from ebay. So who knows how much use this pump saw. Replaced it with a 150psi coolingmist pump and it works great. Just have to watch the mix...and keep the resivoir full.
Thats the problemb with mech inj...if you were to go with 150-200psi pump you will virtually vaporize all the liquid instead of relying on the rotors to mix the stuff..
Old April 18th, 2010, 06:03 PM   #30
limited's Avatar
by mechanical injection I ment like enderle, hilborn(like one on the eng. in my sig.), crower, kinsler etc. I was just saying do not use any alum. fitting's such as russel etc, methanol(pure)eats alum like candy
Old April 18th, 2010, 06:49 PM   #31
1992 Mustang GT
auto-X only
pber13 is on a distinguished road
great link. I remember reading that article awhile back and was looking for it! does a great job of explaining the benefits
Originally Posted by dcook_14 View Post
Well to me, really doing anything to the American flag is defacing it. Unless you're
using it to strangle terrorists, then you get an A+ from dcook
Old April 18th, 2010, 09:03 PM   #32
MyCarPwns84's Avatar
MyCarPwns84 is on a distinguished road
Send a message via AIM to MyCarPwns84 Send a message via Yahoo to MyCarPwns84
Snow Performance
Snow Performance kits for Positive displacement Blowers/Turbos. This is what I'm looking at getting. It comes with a monitor that shuts off the pump solenoids and retards timing when you run out of fluid, so no worries of detonation.
MM&FF Installing Snow Performance Water/Methanol Kit
MM&FF - Methanol Vs Race Fuel
http://www.moddedmustangs.com/forums/signaturepics/sigpic29362_6.gif
Check out the My Garage for updated list of my current parts.
OEF 2010-2011 Afghanistan Veteran
Old April 19th, 2010, 07:44 PM   #33
KB'd GT
The bigger the shot the worse it is. (and the more you need it). I would say that it depends on your goals. If you are a weekend racer with another DD, and can pay for the consequences, go for it! (or just use race gas)
Old April 19th, 2010, 11:43 PM   #34
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
idk 2 of the Tuners around here. One being well know, love the water/meth injection.
Threads Similar to: meth injection
Tuning meth injection question JTs03v6 General Tech 3 April 26th, 2010 08:48 PM
P1sc with meth injection ? klep2024 99-04 0 August 9th, 2009 01:10 AM
Meth Injection 330CubeGt General Tech 0 June 22nd, 2009 10:43 PM
Meth Injection Installation Questions mbmconstruction00 99-04 6 June 27th, 2008 05:45 PM
water/meth injection minigunner7point62 V6 Mustangs 11 August 5th, 2007 09:16 AM
