My diff.
Old April 15th, 2010, 11:13 PM   #1
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
My diff.
My diff makes some weird mechanical noise when i drive. I can hear it on the freeway/highway, and when i make a right turn i hear some other weird sound, i don't know if it could be my tires rubbing the fenderwell or whatnot, but it only happens during right turns. However i want to know!!!
I got this diff recently, guy who put it in said it was rebuilt. I don't doubt him, he's a pretty skilled guy and very trustable.
Old April 15th, 2010, 11:59 PM   #2
1997 Thunderbird
14.06 @89.53 needs tuned
Dirtyd0g is on a distinguished road
I suspect a bad wheel bearing, or wasted carrier/spider gears. It could be new clutches breaking in, how much friction modifier did you put in it. I personally use 2 for OEM traction locks.
Alan
Old April 16th, 2010, 12:42 AM   #3
Imran's Avatar
01
Not sure. A shop did it for me. He replaced mine because my spider gears were shot. I've had it for a while now, i'd say 6 months more or less. I'm gonna ask him too.
Old April 16th, 2010, 02:12 AM   #4
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
um i would say the backlash is off, when your turning right the carrier is moving over and hitting the pinion at a weird angle, mine did that becasue one of the carrier bearings must not have seeded all the way down and when i drove it it finally did then when i turned right it made a grinding noise pulled off the diff and rechecked everything and the back lash was off significantly, added some shims and got it within tolerance and stopped making noise right away after reshiming it.
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old April 16th, 2010, 02:17 AM   #5
Imran's Avatar
01
i'll call the guy tomorrow. he's a nice guy, won't give me any BS.
Old April 16th, 2010, 02:24 AM   #6
2001 Mustang GT
8.98 1/8
ya hopefully nothing happend to the ring gear or the pinion,,, mine took a couple chips out of pinion ( wasnt to happy about it ) people said it would be fine since they were very small on the tip been running it for a year after that happend and not one problem ... but i just got moser 31 spine and a detroit tru trac and im debating throwing in new gears when i install them since ill be launching on slicks and dont want a piece to break on the already chipped pinion and screw up the tru trac
CHECK MEH GARAGE
Threads Similar to: My diff.
2 diff dynos 2 totally diff readings 03snakeminated 4V / SVT 45 December 4th, 2008 03:52 PM
need help with diff.... 88stangGT 5.0 Mustangs 3 May 16th, 2008 12:38 AM
ET diff with 4.10 vs 3.73 njstang 99-04 8 May 6th, 2008 03:29 PM
filling up the diff rollin_loud V6 Mustangs 6 April 15th, 2008 07:58 PM
How much diff will it get you? scxc15 V6 Mustangs 8 May 20th, 2007 02:38 AM
