Bringing Yellow Back
struts
since i have a lowerd car do i need fox struts?? i can get my hands on some pretty easy.
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
What are your spring rates and what rate are the fox dampers set for? How big are the fox dampers compared to our stockers?
Do the Right Thing, Cook. ~Zip. |
1981 4 EYED FREAK
9.48@147
I am guessing you have eibach lowing springs or something of that nature. I have really never seen any problems from stock struts(in good shape) on a lowered car... We lower them all the time with all types of springs and have no issues...
![]() www.rodeheavershotrod.com 9.48@147 on pump gas through the mufflers, still has pw,tilt,t-tops,all lights, wipers!!! , check out the vidhttp://www.youtube.com/watch?v=SloE3Zdetac |
mine only have 40k on them, im posotive that is the problem. i have ruled out everything that the small clunk could be down to the struts. iv tryed the stockers and a set of blue tokiko struts i have also. they both make the same "clunk". im going to get some fox ones from work and give them a shot
2003 Mustang GT
14.03@100
That's quite odd that ur struts are shot. Mine has 102k miles on the stockers, lowered 1.5" and it still ride great.
i know its weird, started doing it after i lowerd it
it really bugs the shit out of me. whatb other things do you guys think i should check??
2003 Mustang GT
14.03@100
Well what exactly is the sound?
BTW-You don't need Fox Struts. Get ones for your car. Unless you plan on getting the Lakewood 50/50 shocks for the back (they only come for Foxes) don't bother w/ Fox parts. Are you looking just for like a Stock-Replacement or Performance? |
its just a weird clunk when i hit bumps, cc plates are tight, ball joint is tight, swaybar is tight and tie-rod end is tight. i had it on a lift last night and checked everything. when i took the tokiko's out the bump stop was pushed to the top of the strut shaft. so im guessing the noise is the strut bottoming out inside its self. i have heard of guys running fox body struts on there cars when they are lowerd becasue they are a shorter strut.
do you think that i should try a pair of those??
Was that bump stop bottomed out before?
Usually stock shocks are fine on lowered cars but there are always exceptions. You could just throw the fox shocks in and see if they help/eliminate the problem
im looking for anyhting that will not clunk when i put it on lol
thanks dcook thats kind of what i was thinking
Cones = Yummy!
YELLOW! 2001 GT VERT
46.496
I have the Eibach Shocks/Struts (pro damper kit) w/ Steeda springs.. when I got the car it had stock Shocks/Struts.. I never had any problems with noises or bumping.. I did notice ride quality improvement with the Eibachs.. I'd check your sways and busings too, sometimes those creak and make noise and they get old..
If the noise is in the rear check the UCA/LCAs too.
![]() Zombie Killing Club | MM Cleavage Club #7 Specs and Pics in the garage... |
i checked all that stuff last night
it is really really bugin the shit out of me
i have that same type of noise. It is the struts. Worn out it seems.
I had a similair issue on a set of coilovers i had on my bimmer as well. |
MM's Official Lucifer
Check underside of hood for clearance of strut top. With adjustable c/c plates the spacers need to be set right so that when cornering or traveling over uneven surfaces the top of the struts don't go too high. When I first installed my suspension I had to go through a little bit of trial and error with that and some puddy to make sure they didn't contact the hood.
LOL I bet. Was that tokico bottomed out before you put it in there. To me it sounds like you're right, and the shock is just bottoming out.
ill check that, but im pretty sure its not hitting that
idk i got a bounch of stuff used, tokio with qai coil over, mm c/c plates and steeda bum steer for 300 so i dont know if they where ever bottomed out before
Threads Similar to: struts
| 87-93 Struts on 04 | MyGT | 99-04 | 6 | October 28th, 2009 01:40 PM |
| Struts | silver99gt | 99-04 | 12 | January 9th, 2009 05:25 PM |
| Struts. | Hudstang | 96-98 | 5 | July 18th, 2007 08:07 PM |
| struts | patwrecked | General Tech | 1 | April 24th, 2007 11:30 PM |
| Struts | Pony_with_an_attitude | 5.0 Mustangs | 16 | March 30th, 2007 03:49 PM |
