Abs Light Is On Help!!!!! Can't Turn Off TRACION CONTROL!!!
Old April 16th, 2010, 09:17 AM   #1
PunisherStang01's Avatar
PunisherStang01 is on a distinguished road
I bought this car (2000 Mustang GT) 2 days ago and have been working the bugs out meaning replacing fuses, sensors, bulbs etc. When I bought this car the front brakes was changed by their mechanic and I looked under the front end and the ABS sensors are plugged in (not sure if the light was on before they changed brakes). The check engine light came on about 40 miles and I took it to AutoZone and the (bank 1 forward of cat) O2 sensor showed bad so I replaced and it runs better now (however the ABS light was on but their machine couldn't read it they said) What do I do to find out which sensor might be bad on which wheel? and or is there something I can do to reset this? I already took the battery positive cable off and it came right back on during start up... Where to they plug in to the car at? The traction control switch did work once, now it wont turn off at all (I checked the fuses for the traction control but I thought is was do to the ABS light)
PLEASE HELP!!!! Thanks
2001 Mustang Roush
www.barefootsurvivalgear.com
Old April 16th, 2010, 09:54 AM   #2
14.2
_Red_Rocket_ is on a distinguished road
do any of the wheels lock up? abs light is on in my cavalier, pretty sure its a bad sensor as just the rear driver side wheel locks up when I slam on the brakes. haven't bothered to fix it yet cause it's just a winter beater and im driving the mustang again lol
try slamming the brakes to see if any wheels lock up?
Old April 16th, 2010, 09:56 AM   #3
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
You could probably OHM out the VSS (Vehicle Speed Sensor) and see if the component is in spec.
Old April 16th, 2010, 10:01 AM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
as Lefty said, you can do a resistance test on it to see if it is out of spec before you go replacing parts. If you can find what the spec is supposed to be then you can check it with a multi-meter and be done with it. all the connections for the front ABS sensors are behind the fender aprons, and the one's for the back IIRC are underneath the rear seat.
BUILD 2 IN PROGRESS
Old April 16th, 2010, 10:03 AM   #5
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Here ya go. Here's how to check it. You need to check the resistance.
Turn the ignition switch to the OFF position.
Disengage the wiring harness connector from the VSS.
Vehicle Speed Sensor (VSS) wiring harness connector terminal identification-typical
Using a Digital Volt-Ohmmeter (DVOM), measure the resistance (ohmmeter function) between the sensor terminals. If the resistance is 190–250 ohms, the sensor is okay.
Lefty = da shiz nit
Old April 16th, 2010, 10:06 AM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
Lefty = da shiz nit
you got the one for the ABS for him?
BUILD 2 IN PROGRESS
Old April 16th, 2010, 10:06 AM   #7
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
maybe check and see if one of those little ends on the sendor is broke off.
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old April 16th, 2010, 10:19 AM   #8
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Not right now...(I'm at work so I need to sneak)
Old April 16th, 2010, 10:33 AM   #9
Spurred Snake's Avatar
2003 GT & 2003 Cobra
Becoming a corner junkie...
Spurred Snake is a jewel in the roughSpurred Snake is a jewel in the roughSpurred Snake is a jewel in the roughSpurred Snake is a jewel in the rough
Try going back to Autozone and see if they can atleast give you a code.
Formerly known as SVT_WANNABE
MILITARY CREW - E-3 - ARMY
ANTI-RICE Founder
*My YouTube Channel*
http://www.youtube.com/user/PS3Turbostangs?feature=mhee
There is nothing SVT can teach me about jizz and swallowing, I assure you
Old April 16th, 2010, 10:51 AM   #10
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
Unfortunatly auto zone probably won't be able to give you a code because they can only read the powertrain codes from the pcm. I do believe they sell a scanner that will read abs codes. Could be wrong.
Also, make sure all you're sensors are clean as brake dust and metal particles like to get in there andjam up the signal
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old April 16th, 2010, 10:53 AM   #11
FoxHoss's Avatar
02' GT
Old April 16th, 2010, 10:59 AM   #12
Cones = Yummy!
YeloPony's Avatar
YELLOW! 2001 GT VERT
46.496
YeloPony is a jewel in the roughYeloPony is a jewel in the roughYeloPony is a jewel in the rough
Tell Jeff, I said it's ok, Lefty has 'more important' things to tend too.. pfft.. work
Do you have a tuner? If so I think that will read the codes.. ? could be wrong..
Zombie Killing Club | MM Cleavage Club #7
Specs and Pics in the garage...
Old April 16th, 2010, 11:14 AM   #13
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
^Some tuner's won't read codes that in depth or sometimes they won't read specific powertrain codes.
Old April 16th, 2010, 02:15 PM   #14
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Are all the tires the same size?
Bolt on list in Garage..
Old April 16th, 2010, 03:13 PM   #15
jeenyus_eh's Avatar
jeenyus_eh is on a distinguished road
This should be obvious, but have you checked the fluid? The light comes on when the fluid gets just a little too low on these things... happened to me. Just a suggestion.
Old April 16th, 2010, 03:29 PM   #16
Thanks for all the input, I have checked the connections on all wheel? Not sure about the VSS (don't know where this is) I haven't tried to stop quick and lock them up, don't have a tuner either, the tires are all the same size and yes the fluid level shows fine. Wow you guys are great at helping out, really wish I was a motor head...
Can you tell me more about the OHM out the VSS...
2001 Mustang Roush
Old April 16th, 2010, 09:37 PM   #17
2003 Mustang GT
13.2@99mph w/slicks notch 14.1@ 97mph
Triton03 is on a distinguished road
On either of your front wheels you'll have wheel speed sensor, also have them on the rear but connectors are harder to get to. These sensor measure how fast all the wheels are going at the same time. say for instance you hit a wet spot in the road and your rr tire spins and your lr tire doesnt, your abs (antilock brake system) will reduce braking power to the tire that is spining or trying to lock up.
In order to see which sensor is not operating properly you'll need a dmm (digital multi meter) which can read ohms. You'll need to go to one of the front hubs and locate your vss (vehicle speed sensor), there should be two wires coming out of the sensor. Trace those wires to the connector. Disconnect the connect and probe the two wire with your ohm meter. Make sure your doing this on the wiring towards the sensor not the ebcm (electronic brake control module) the sensor should ohm over 1000 ohms not spinning the wheel.
If that checks okay, turn your meter to amps or ac voltage cannot remember at the moment. continue probing sensor side of conector and spin your wheel. Should read 200+ easily, if the sensor is working properly.
Old April 19th, 2010, 12:13 PM   #18
Thanks Again, guess its to the shop it goes...
I seen the color mustang groups, whats up with that? I got Black & Blue...
2001 Mustang Roush
Threads Similar to: Abs Light Is On Help!!!!! Can't Turn Off TRACION CONTROL!!!
ABS Light? DickH 99-04 9 November 25th, 2009 11:06 PM
ABS light wont turn on scooter1 96-98 2 October 1st, 2009 06:43 PM
03 gt with ABS light on mtw002 99-04 16 December 26th, 2008 06:03 PM
ABS light cbrown 99-04 8 August 20th, 2007 11:01 AM
ABS light j2000_guy 94-95 3 March 29th, 2007 12:42 PM
