2002 Mustang GT Vert
Newbie needs help with Speedometer Prob
Hello everyone. Just bought a 2002 GT Convertible-automatic. I drove it home to Vermont from Florida. Ran great but did notice the speedometer was reading about 9 miles per hour faster than speed showing on the TomTom navigation unit. When traveling at 80 mph on the speedo (probably closer to 70)the tach was about 2400 rpm. I also noticed when the car idles the tach shows about 700-800 rpm, but the engine sounds like it is revving much higher. The only mods that I have seen so far are a KN Induction, nonstock exhaust, wheels are 17 inch cobra. Any help would be greatly appreciated.
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
I'm guessing you have a higher than stock gear ratio and it's throwing off your speedo. Jack the back tires up and spin the wheel one rotation while having someone else count how many times the driveshaft goes around. If it's about 3 1/4 turns of the driveshaft you have stock gears, if it's more like 3 3/4 then you have 3.73s and if the driveshaft turns a little more than four times for every one rotation of the tire, you have 4.10s. Do that and let us know what you find.
Do the Right Thing, Cook. ~Zip. |
According to the halfass calculator that I built, if you were in fifth gear at 2400 rpms with stock tires and 3.73s, you'd be going 70. The speedometers on GPS units are pretty damn accurate, so I'd be willing to say it was right and your car speedo was wrong. I'd be willing to bet you have 3.73s in your car and you're not tuned for it, so it's throwing your speedo off
!FACEPLATED!
If it does happen to have gears in it and you arent tuned, get a tuner asap since you are an auto. Having gears and not being tuned for it is doing more than just throwing your speedo out of wack
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
Moderator
2012 300a gt auto
12.10@116
+1^ get this sorted out right away before you end up putting a trans in.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
SLOW :(
Gears won't mess up a transmission. What should be looked at though is the tailshaft lube mod being done. When I had my 95 Tbird I just used a speedcal and called it a day. That's my 2cents though.
#7 | |
MY OTHER RIDE IS YOUR MOM
![]() “I Saw Elvis at 1000 Feet” "I was doing fine until about mid-corner when I ran out of talent." |
SLOW :(
!FACEPLATED!
gears do so mess up an auto trans. The readings from the VSS are not correct when you dont reprogram for the different gears and makes the tranny shift at times when its not suppose to. Thats why everyone says to get a tune asap when you do gears with an auto
#10 | |
SLOW :(
You do realize that a speedcal does correct the input to the computer right? That is all that matters really. A tune is nice if you did other mods to warrant is fine but not really needed. |
!FACEPLATED!
exaclty, you corrected the problem with a speedcal. Without a speedcal or tune to give the vss the correct reading it will hurt the trans. Not saying its going to grenade it, but it does do other harm
#12 | |
Moderator
2012 300a gt auto
12.10@116
Threads Similar to: Newbie needs help with Speedometer Prob
| prob | mpboy | 99-04 | 1 | March 5th, 2008 09:46 PM |
| Help GF Prob | Till | The Clubhouse | 53 | February 25th, 2008 10:20 PM |
| sniper prob!! | WLJohnson05 | V6 Mustangs | 41 | July 30th, 2007 12:16 AM |
| clutch prob? | thatonekidw/theGT | Modular Mustangs | 12 | July 18th, 2007 09:29 PM |
