ac question
Old April 16th, 2010, 03:52 PM   #1
vandy0090's Avatar
2003 gt
25.06@ 15.45
vandy0090 is on a distinguished road
ac question
So I pulled the 03gt outta storage and have found the ac doesn't work. I went to recharge the system and found the compressors not kickin on. I know my 02 f150 had a safty shutoff switch if the freon (sp) was low. Here's my question. I've got a servicing port by the radiator one by the pass side fire wall both have black caps on them. I believe the one by the firewall is the low press fitting. There is another fitting right by it with a blueish green cap on it. Not sure what that is? Any thoughts. And do u need to set a jumper to the compressor to get it to move some freon to get it to charge. I had a bottle set up on what I believe is the low press side car running ac on full bast and it never kicked the compressor on and was runnin for about 15 min?
Old April 16th, 2010, 05:04 PM   #2
1999 GT Conv. 3xblk
Get the Black Chicken is on a distinguished road
Send a message via Yahoo to Get the Black Chicken
First, get some ac dials (gauges) check were your pressures is at. The system you have is 134a so make sure the dial are 134a. Second, make sure you have pressure on the low side (blue fitting) high pressure will also show but don't worry yet. Third, test the connector wire that supplies 12v. to the coil on of ac compressor. If this wire has 12v the coil on the compressor is bad. Hope this helps to getting you in the right direction.
"What ever you do don't touch the Traction Control button"!
Old April 17th, 2010, 12:28 PM   #3
2003 Mustang GT
13.2@99mph w/slicks notch 14.1@ 97mph
Triton03 is on a distinguished road
" blueish green cap" has nothing to do with the ac, pretty sure what your talking about is for you EVAP system.
Get some gauges on the system and tell us what your low and high side pressures are.
Old April 17th, 2010, 12:36 PM   #4
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
^ nah hes talking about the blue cap. a lot of cars have the a/c caps color coded, but the OP noted both his were black.
and yea the green cap is for EVAP testing
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Threads Similar to: ac question
Answer A Question With A Question.. yeah_itsa_v6 Forum Games 172 August 11th, 2011 07:52 PM
Exhaust question and tuner question.....dont laugh lol Drick 99-04 19 September 24th, 2009 03:42 PM
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 01:31 PM
Exhaust question + supercharger (warranty) question r00st 2005 - 2010 2 January 31st, 2008 11:07 AM
Muffler question (visual aspect) + Emblem question warrior86 Visual 5 November 20th, 2007 09:55 PM
