2002 Mustang GT Auto
![]() iTrader: 2 reviews
Nitrous wiring.. Where does this wire connect to?
I have this nx TPS switch http://www.nitrousexpress.com/Instru..._autolearn.pdf
it says to connect white wire to ecu, anyone have a picture of where that is on a 2001 gt |
!FACEPLATED!
connect it to the Throttle Position Sensor output voltage wire. The correct TPS wire will have around .5 volts when the throttle blade is closed and around 4.5 volts when the throttle is opened fully. These are not exact voltage numbers, but simply give you an idea of the proper voltage you should be seeing
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
F8L is correct
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
!FACEPLATED!
If i remember correctly, its the middle wire. I cant go look at mine since i didnt connect it at the sensor. I connected it farther down stream so it was hidden and out of site, looking cleaner
so the white wire from the tps switch goes to one of these wires circled here:
![]() there are couple of gray wires and 1 brow wire, which one is the right one |
2003 Mustang GT
12.28 @ 116
It is the middle wire
Threads Similar to: Nitrous wiring.. Where does this wire connect to?
| Ground Wire Gauge.. Same Size as Power Wire or No? | warrior86 | Audio/Video | 4 | January 30th, 2010 06:41 PM |
| Wiring for 2-step/nitrous launch | DSG40TH2V | 99-04 | 8 | June 23rd, 2009 11:42 PM |
| Wiring Nitrous up. | C0BRAK1LL3R | 99-04 | 14 | April 21st, 2009 05:05 PM |
| what does this connect to? | fateisajester | 96-98 | 3 | March 31st, 2009 08:13 AM |
| can't connect battery | texasd18e | 99-04 | 8 | February 8th, 2009 08:00 AM |
