Bullitt shocks/struts
Been searching and can't find them anywhere except with the kit. Anyone know where I can get them?
i think they are the same as the mach 1's if that helps at all.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Thanks for the reply, but unfortunately they have different part numbers. The Mach is set up for drag and the Bullitt is set up for street. I guess its off to the dealer tomorrow.
03 gt, 95 740i, 96 disco
![]() ![]() iTrader: 2 reviews
whats different with bullitt?
Apparently the shocks for one. Sway bar is different also, or at least the Bullit kit comes with one. I think the springs are the same with the Bullitt and Mach, at least the spring rates are. The bullit has C-springs which I have, and I wanted the shocks to match because my stockers don't work well with c-spring rate.
2001 Bullitt
12.25@110.4
The fronts measured the same as the Mach 1, but the Bullitt rear shocks are stiffer than the Mach. The Mach 1 rides noticeably softer than the Bullitt, even though they have the same spring rates. The swaybars are larger on the Bullitt also, but still kind of wimpy. I swapped to a 30mm front from a 98 GT and the 28mm rear from a 95 Cobra.
I have found the struts by themselves, but unfortunately, it's cheaper to buy the entire kit than just the shocks and struts nowadays. |
got ya. yea i just have eibach shocks and struts with their springs, I love that set up.
2001 Bullitt
12.25@110.4
The FRPP "C" springs are very aggressive compared to most aftermarket springs. They are also linear, so there's no comfort zone like the Eibach's progressive rate springs.
What would be a comparable shock that would go with the c-springs?
2001 Bullitt
12.25@110.4
The Tokico Blues are almost the same as the Bullitt shocks and struts. If you want to spend just a few more dollars and get a much better shock, go with the Koni STR.T's from Jegs. Better than the Tokicos and the stock Bullitts, and only $350ish.
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
I got Bullitt shocks/struts sittin in my garage if you are interested.
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
Cervini Stalker kit, Foose 18" Nitrous 265/295 Manley rods & pistons, Kellogg crank, ATI 10%OD, Fidenza flywheel, Spec3 clutch. Kenne Bell 2.2L,8rib conversion. Headers, Xpipe, Magnaflows JLT, SCT Eibach, H&R, Tokico, Maximum motorsports |
#13 | |
Threads Similar to: Bullitt shocks/struts
| Shocks/Struts | baine21225 | 5.0 Mustangs | 16 | September 28th, 2009 10:35 PM |
| Which shocks/struts to get? | Abe02GT | 99-04 | 5 | July 9th, 2008 06:59 PM |
| what do to with used struts/shocks | hardhitter | 99-04 | 10 | June 25th, 2008 11:55 AM |
| Shocks Struts, and Quad Shocks? | 2000roush | 99-04 | 2 | December 4th, 2007 07:27 PM |
| Shocks/Struts | DCstangGT | 99-04 | 5 | November 2nd, 2006 05:34 PM |
