Master cylinder bleeding
Old April 18th, 2010, 04:53 AM   #1
1999 Mustang GT
13.8@100
GTCON is on a distinguished road
I am about to bleed my brakes soon to put on my Roush/Alcon big brake kit. I just want to make sure I got some of the sequences right. From what I have heard I thought bleeding the master cylinder (by the 2 bleed screws) and then the RR, LR, RF, LF was correct? Some people have said to bleed all the wheels first and then the master cylinder? Let me know what is the best way to go about doing this.
Also, Ive never bled the master cylinder by the bleed screws. Is it the same process as the wheels? (pump up to get pressure, press and hold pedal while one of the bleeder screws is opened, then close the screw before letting pedal go, and repeat). And which screw should be bled first? The one closest to the firewall or the one closest to the battery, or can they be bled at the same time?
Please let me know any info, and thanks in advance!
Old April 20th, 2010, 03:05 AM   #2
1999 Mustang GT
13.8@100
ttt
Old April 20th, 2010, 09:16 AM   #3
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
I did my wheels then went to the master then back to the wheels. Not sure if it's the easiest way but it worked.
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old April 20th, 2010, 01:00 PM   #4
Evil Klown is on a distinguished road
you wont have to bleed the master cylinder unless you are replacing it with a new one or you let the brake fluid reservoir drain completely. Just bleed all of the calipers and make sure you keep an eye on your fluid and fill it as needed, you should be fine.
Old April 20th, 2010, 02:28 PM   #5
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
If you were to drain the whole system though, would black five ohs method work?
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old April 20th, 2010, 09:08 PM   #6
1999 Mustang GT
13.8@100
I want to bleed the master cylinder because ive had a bit of a spongy pedal ever since ford did my last brake job (i didnt really know how to do them at that point). I got the brakes bled after the job and it still didnt do too much and ive read that bleeding the master might get it back to being rock hard.
Threads Similar to: Master cylinder bleeding
clutch master cylinder dave364634 2005 - 2010 0 September 7th, 2008 10:39 AM
Master cylinder decesion's darkhorse50 5.0 Mustangs 2 May 22nd, 2008 08:45 PM
noise from brake master cylinder... dansgt 99-04 3 February 14th, 2008 02:22 AM
Master Cylinder Reservoir WAR-PARTY 99-04 0 October 10th, 2007 07:04 PM
master brake cylinder Invictus 99-04 0 February 5th, 2007 01:36 PM
