PTV issues with comp stage 3 blower cams?
Old April 18th, 2010, 02:16 PM   #1
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
I have an opportunity to go from my vt stage 2 blower cams to comp stage 3 blower cams for cheap/nothing. But i am wondering if there are any ptv issues with them.... I have seen people say they have run vt stage 3s with stock pistons and as far as i know they have a higher lift to duration ratio than most of the other cams. any help would be appreciated. Thanks
Old April 18th, 2010, 02:25 PM   #2
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
DO IT! lol if they decide to make contact then its time for a built bottom end
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old April 18th, 2010, 02:38 PM   #3
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
I would just search around to see if people have ptv issues with crowers, I personally don't know.
It is more the open and close events that effect ptv than lift or duration
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old April 18th, 2010, 07:00 PM   #4
1992 Mustang GT
auto-X only
pber13 is on a distinguished road
when you put your current cams in, how much PTV was there? how much more lift do the stage 3 cams have vs the stage 2?
Originally Posted by dcook_14 View Post
Well to me, really doing anything to the American flag is defacing it. Unless you're
using it to strangle terrorists, then you get an A+ from dcook
Old April 18th, 2010, 07:29 PM   #5
It has a built bottom end already
Old April 18th, 2010, 07:52 PM   #6
limited's Avatar
If your talking to me, I never checked with dial ind.
actually vt stage 3's have less lift than vt's stage 2's
Old April 18th, 2010, 08:31 PM   #7
Rabid Stang's Avatar
1999 Mustang TermiGT
Rabid Stang will become famous soon enough
Limited we need to start the LE Club!!!!
Old April 19th, 2010, 07:28 AM   #8
1992 Mustang GT
auto-X only
meant the op. if the cams he wants to put in have less lift, I really don't see there being a PTV problem...
Old April 19th, 2010, 06:15 PM   #9
ajm
Theres more factors than lift that effect ptv.
Old April 19th, 2010, 09:00 PM   #10
if its an 18cc dished piston would it have ptv issues?
Old April 19th, 2010, 09:55 PM   #11
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
Lift isn't the problem, it's a combination of lift, centerline and duration that causes problems.
Old April 19th, 2010, 10:11 PM   #12
limited's Avatar
these play a role, but the opening and closing events(as I stated in post #3) is the main culprits in ptv issues. Thats why some large cams don't have ptv issues and smaller cams do
Threads Similar to: PTV issues with comp stage 3 blower cams?
vt/cms stage 2 ptv issues? mystang0673 99-04 11 May 3rd, 2009 01:30 AM
VT Blower Cams Vs Comp 270's 97GT4.6 96-98 13 December 16th, 2008 04:42 PM
BBR Stage 2, FRPP Hot Rod, Comp Stage 4 or Comp Thumper Cams ivan48humble 2005 - 2010 179 December 8th, 2008 02:19 AM
COMP cams stage II 270s PTV clearance issues? Saleen0101 Modular Mustangs 13 September 11th, 2008 03:06 PM
