Steeda Underdrive Pulleys
Old April 18th, 2010, 04:48 PM   #1
Nipsco is on a distinguished road
I am thinking about buying some Steeda Underdrive Pulleys and wanted to get some feedback from people that have them. Are they worth the $200 price tag and how would you rate the installation difficulty? Also, I read that if you plan on supercharging down the road that these pulleys wouldn't be compatible and you would have to put the old ones back on.
2004 Dark Shadow Gray 40th Anniversary Mustang GT 5 Speed
Steeda Short Throw Shifter
3.73 Gears
K&N CAI
Diablo Sport Predator Tuner
Accufab 75mm Throttlebody, Plenum, and Intake spacer
Accel Super Coil on Plugs
NGK G-Power Platinum Spark Plugs
Old April 18th, 2010, 05:00 PM   #2
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
Well... if your willing to shell out $200 go for it. I wouldn't think they are worth it, but they are a bolt on and will add up eventually. Try looking for a set of used ones if you can find a set. And that is true, as these pulleys are designed to slow down accessories which would cause the s/c to not push as much psi.
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old April 18th, 2010, 06:47 PM   #3
SLOW :(
ESABATM is on a distinguished road
Easy install but you want to make sure you either get an ARP crank bolt or a new bolt from Ford. They send a bolt in the kit only to get the damper started.
And what you read about supercharging in true. I don't care since I plan on staying N/A with a shot of nitrous in the future.
2000 GT Spring Edition
Damn money Pit
http://www.silverdollarraceway.com
Originally Posted by 01MGGT View Post
I am a 1/4mile guy so performance steering isn't really important.
Old April 18th, 2010, 06:56 PM   #4
3sportbob's Avatar
MY OTHER RIDE IS YOUR MOM
3sportbob will become famous soon enough
I thought about that but the more I read the more I wasn't sold on the benefit. Be carefull with the bolts if you do it. I personnaly would rather spend the money elsewhere.
“I Saw Elvis at 1000 Feet”
"I was doing fine until about mid-corner when I ran out of talent."
Old April 18th, 2010, 07:08 PM   #5
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
As far as under-drive pulleys go, Steeda is your best bet. There are some out there that can cause problems, but from what I have seen, Steeda is good.
Black Stang Crew #007
Car Built By Me and CraigsList.com
Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads.
More to come! I hope.
Old April 20th, 2010, 07:11 PM   #6
Well after consideration I have decided to skip the under drive pulleys and put my money towards new headers, x pipe and cat back exhaust. The main factor was that I plan on supercharging down the road and do not want to replace the steeda pulleys again. Thanks 4 all the advice guys.
3.73 Gears
K&N CAI
Old April 20th, 2010, 07:56 PM   #7
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
I have the Steedas, but bought them used from a friend who went supercharged, and didn't need them anymore. I wouldn't have bought them brand new, because I don't think the slight gain is worth the cost, but used for $100 or so, they start to be a better deal.
Threads Similar to: Steeda Underdrive Pulleys
Steeda Underdrive pulleys bamagt 2005 - 2010 16 June 8th, 2008 09:03 PM
Steeda 4.6L Underdrive Pulleys 04whiteGT 99-04 12 February 22nd, 2008 05:45 PM
