what can cause engine misfire?
Old April 19th, 2010, 03:05 AM   #1
tweety_5150's Avatar
2000 GT Convertible
tweety_5150 will become famous soon enough
i have a 2000 gt it misfires not so often and the check engine light starts flashing i check the code and its cylinder 3 and 4 i already changed the spark plugs but it still keeps on happening any ideas?
Old April 19th, 2010, 04:08 AM   #2
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
Could be the coils, try checking them with a multimeter or something, if it's not them it might be an injector? There are a lot of things that could cause a misfire, start ruling things out by checking the obvious.
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old April 19th, 2010, 07:32 AM   #3
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
There's only 3 BASIC things that will cause a missfire. Lack of fuel, compression, or spark. Start by figuring out which one you're missing and go from there. Like JerseyTrueBlue said, it's prolly coil pack or injector.
I would start by swapping the coil packs on cylinders 3 and 4 to other cylinders. When the CEL comes on again, see if the missfire has moved to the other cylinders.
Old April 19th, 2010, 11:29 AM   #4
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
+1 move the cops to the other side, see if misfire follows. Then it is the cops.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old April 19th, 2010, 11:41 AM   #5
2000 GT Convertible
alright ill try and see if its the coil packs. how hard is it to changed them?
Old April 19th, 2010, 11:45 AM   #6
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
I was getting my engine back together yesterday after a plug fouled out. Short story, I still dont know why but I noticed a weather tight seal for the injector on the cylinder isnt there. Not sure when I lost it but, its easy to make sure they are there. Cant hurt.
Old April 19th, 2010, 11:49 AM   #7
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
You take a bolt out of the top, take the old one out, put the new on in, re-bolt it, re-clip it. Should take about 30 seconds per coil
Do the Right Thing, Cook. ~Zip.
Old April 19th, 2010, 11:50 AM   #8
iTrader: 7 reviews
Yeah those little o-rings pop off pretty easily. You can order new ones from Ford if you need to. I wouldn't use a regular o-ring since it's getting gas against the rubber... it'd probably eat regular ones after a while
Old April 19th, 2010, 12:42 PM   #9
2000 GT Convertible
wow i would of thought it would of been more hard ill give it a try later in the day.
Threads Similar to: what can cause engine misfire?
A Misfire? lobo_loco 99-04 4 October 19th, 2009 07:23 AM
misfire?? 2006greyGT 2005 - 2010 8 April 29th, 2009 12:21 AM
Misfire on #8 TG02GT 99-04 6 July 19th, 2008 10:52 PM
misfire mpboy 99-04 0 May 25th, 2008 07:46 PM
misfire.... stang fanatic General Tech 10 June 23rd, 2006 10:08 AM
