2000 Mustang GT Vert
Something wrong with my driver side window
I have a convertible 2000 gt and my driver side window doesn't seal when I shut it. Its hanging off about a quarter of an inch. I'm replacing the top because its in pretty bad shape but I'm thinking that wont fix it. Do I need to buy a new driver side window? Will getting a new vert top fix my problem? are there any other solutions? Any advice? Also my passenger side window seals fine. Here are some pics.
Inside driver side ![]() Outside driver side
Did someone try to break into your car? It looks like the window has been popped off the brackets on the power window assembly. Pull the door panel off and have a look. Could be the window, the assembly ,or the tracks.
I've had the car like a year. The previous owner never told me anyone broke into it so to my knowledge no. 100% no since I've had the car. I'll check that later on today and see
I had the same problem with my previous 02 coupe. I don't know what causes it, but I see it alot with New Edges.
what did you do to fix that?
Mine is a coupe, what happened is someone tried to break in by prying the window back, popping it off the bracket and reaching inside to unlock the door. I had to pull the window, because the window was not glued to the bracket anymore. When the thief pryed the window it widened the bracket which gave the window all kinds of play. I pulled the window, drilled the rivets that attach the brackets to the power window assembly, reglued the window to the brackets. Through all back together again, put bolts in where the rivets were. I hope this helps.
Has there been any fix to this? Im bringing home an 04 cobra with the same problem, and need a solution!
2006 Mustang GT ![]() American headers, Magnaflow axlebacks, Fang Shaker, Steeda UDP, C&L Street CAI, Comp Thumpr Cams, CMCV Delete plates, 4.10 gears, Tri-ax, SCT Tune, Panhard bar, Steeda springs, Steeda sub frame connectors, and some other crap |
2001 Mustang GT
I have a coupe that had same problem. It was the rear bracket that came loose for me inside the door. One of the rivets came loose. I just took a small self tapping screw and put it back so it sat level with the glass. I did it about 2 mos. ago and no problems so far. I'm sure you could do more to secure it than me if you want to.
#9 | |
2000 Mustang GT Super'ed
![]() iTrader: 2 reviews
Read this thread: Door Window Glass Separated from Bracket / Need Glue Advice
![]() Saleen Series II 377whp/390wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Spec Stage 2, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, X2 Balljoints, Cobra Brakes, SS Lines. |
2001 Mustang GT
13.65 @ 102.88
It's a notorious problem with New Edges. All you need to do is roll down the window, then roll it back up and it should fit back into place. The seal isn't perfect, but it's a lot better. Mine does this every time someone opens the door, and when they try to shut it, the window pops out. My shop quoted me at + or - $400 to replace the window internals to have it fixed. Not worth it in my opinion. I'd rather just roll the window down and back up.
Amazon Green GT Everyone loves bolt-ons
#11 | |
2001 Mustang GT
13.65 @ 102.88
Well that response seems a little harsh man. Might want to calm it down a little. But I'm not having any issues with my car. It's not causing any undesired problems. It's a simple press up and down on the window button to solve the seal problem. Rain doesn't come into my car. Washing my car I have no leaks. So what is the problem dude? It's not a big deal. And sorry for not reading your thread. I saw the initial post and made a response, didn't want to read everything everyone had to say.
#13 | |
2001 Mustang GT
13.65 @ 102.88
It's all good man, no hard feelings. But I'm sure you're right. Once I get done with finals I'll probably take a good look at your thread and put some work in on the window.
Threads Similar to: Something wrong with my driver side window
| Driver side window problem. | weems | 99-04 | 8 | October 22nd, 2009 08:56 PM |
| driver side window motor | ryanthegreat | 99-04 | 1 | June 30th, 2009 07:53 AM |
| 02 Driver side window not seating right... | HandStang | General Car Care & Detailing | 2 | May 27th, 2009 08:43 AM |
| driver side window issues | joejoe8455 | 99-04 | 2 | April 20th, 2009 07:28 AM |
| aggressive driver side lean *PIC* included. what could be wrong? | buddyantunez1 | V6 Mustangs | 6 | November 16th, 2008 12:54 AM |
